Originally Posted by TC in EC
Since the black level issue is related to the initialization voltage, could you use a Variac (http://www.variac.com/) to lower the voltage going to the TV? I'm no engineer, so someone else with the proper technical background might be able to determine if this would lower the MLL, and if there would be any negative side effects such as lower overall brightness, possible pixel misfiring, etc.
NO, that would not work: the adjustment is for a particular circuit only
