I don't know if there is still someone interested in this, but I was able to fix this issue
. I don't know if my black levels are completely reset, but there is an improvement.
Here is what I did:
I don't have much time now, but if there is interest in this i can write a more detailed HOW-TO. Perhaps we can find even more settings in this EEPROM.
Here is the result:
Thanks to everyone in this thread for valuable information!!
. I don't know if my black levels are completely reset, but there is an improvement.Here is what I did:
- Remove the rear cover and rear terminal cover, so you can access the A-Board
- There is a 11 pin connector for factory adjustment. connect an i2c master (I used an AVR with my own firmware) to pin 8 and 9 and pull 10 to GND, which will mute other masters on the bus.
- The panel eeprom has the address 0xa0 but is unfortunately write protected. Remove the write protection by pulling the following VIA to GND (I used a thin wire).
- Now we can write to the eeprom. the panel aging is saved from 0x0001 to 0x0006 (right at the beginning
). Just set these 6 bytes to zero and you're finished. Note that this is not the same clock as in the PEAKS EEPROM, which was already reset by other users with no effect.
Here is the result:
This is amazing and unexpected news -- if you post a detailed How-To guide, you will surely go down in AVS history! THANK YOU!
