Originally Posted by zylch
I received a German 50V10E set two weeks ago and it has been sitting in its box ever since while I'm scratching my head trying to decide whether to keep it or return it (which I could do at no cost until the end of the month).
According to Turrican4D, these German models make their first jump between 80 and 120 hours (probably 100 hours?), which means having to reset the clock to 00 every 79 hours at most to be sure. If that's the case I would return the set tomorrow, as I don't fancy having to do this every few days, at the risk of messing something up big time. Alternatively, Turrican4D also suggests setting the clock to something really high like 4000 hours on a new set, and forgetting about it, which seems much more sensible.
So just to be clear, and assuming Panasonic do not release a fix for this issue, my questions are:
- Can the problem definitely be avoided by applying the EEPROM clock reset on a new set?
- Has anyone tried setting a high clock count (> 2000 hours) from the start on a new 12G set?
- What happens when the pixels start misfiring after about 2000 hours, would I then allow it to make its first voltage jump and then keep it somewhere between the first and second, perhaps between 100 and 200 hours? That would then bring back the situation i wanted to avoid. Or should I then allow it to go through all its cycles?
It is nuts to go messing with a brand new tv's firmware unless you are a Panasonic engineer. This thread makes it sound like every tv does this. I don't believe it. If you are seriously considering editing the firmware instructions in hex before even unboxing the thing bring the TV back and get a different brand/make/model.
