Originally Posted by thebigdaddye
they might be scams from BB when you have to pay a quarter of the cost of the tv for the warranty, but if you get one from mack cam ,cps and only pay a couple of hundred or less for 3 years of additional coverage from the manufacture warranty it's well worth it even if you never use it. if you use it once it's paid for itself as replacement parts and labor will be more then the cost of the warranty. plus if they cant fix it at least you will get something out of it and not just throw it in the trash. i purchased a mack warranty and i am glad to know i don't have to worry about the tv for 3 years and i'm out less then a $100 for it.
Only about 4 percent of sets are failing the first four years. And most of the failures are in the first year under the factory warranty. IMHO you are still better off to take your chances. Mack etc is collecting 10 grand in warranty fees on 100 sets, and fixing or replacing about four of them. Sweet deal huh?
But if you have to get a warranty, Mack is a much better deal than Best Buy etc.
