[quote=Orta;16934747]Thanks bat, useful bit of info to have. I had tried doing this kind of reset myself, but could only find the "Store Mode" reset that's in the manual. Sadly, this didn't seem to do anything for my problem. Black levels weren't affected at all. Do you remember any of the other potential solutions they had you trying?
The other suggestions made were to check my connections, make sure it wassn't something going bad with the hdmi or component board, but if it happens when using the side hdmi then its something else because this connection isn't on the same board as the other two, so after that he wanted to know about my player's and set top box, but all of this checked out fine of course, so next he said the only other options were to do the reset, schedule a repair order to have a tech check the set out, or have it pro calibrated to suit my black level desires, but fortunantly the reset worked for me. sorry i don't have any better info for you to go on..........
