Originally Posted by jackal2001
Question about Infinite Black Feature.
I set my tv to vivid on an input that wasn't being used. The tv didn't do anything. It just sat there at a well blackish screen. I didn't see it change like the tv turned off.
I have a tech coming out to look at my tv for something else Thursday. Is this infinite black feature documented anywhere that I can point them to it?
Has anyone gotten anything replaced in their tv to fix this yet?
I have commented on this a couple of times. I used the infinite black problem along with the IR to get panny to send a tech to my house. I am waiting on parts to be replaced. Infinite black is a well advertised "feature" of this set. If it doesn't work they have to fix it regardless of whether it is a useless feature or not.
your readings fit the pattern for what we would expect for a 50" set with 500+hrs, somewhere btwn 0.015-0.020...
seems you are still happy with the set, and the PQ is still great overall. It does continue to raise the issue of what is "normal" and whether Panasonics needs to worry, since the vast majority of their customers probably would never notice the difference between 0.008 and 0.018...
