Originally Posted by battousai147
Orta (or Dnice for that matter), i was wondering something. I am sure you know what ghosting is, or at least this is how i refer to it, when you have a bright image on the screen for a few moments then go to a completely black screen you can still see a very faint outline of the image, i guess this would technically be IR. I wonder if this is occuring on a much larger scale on these sets. I have been using the set for about 10 to 12 hrs straight today, kids watching tv, of course myself, plus a little hard core gaming, buy any case just a bit ago i decided to put up a completely black image, its one that is off of the break in images, and bam the black level is lighter again, i also poped in a bluray just to confirm, i tried the reset this time but still the same.
My question that im finally getting to is this, after having the set on so long, could the black level be lighter because of a residual charge built up just like ghosting, this time over the entire screen where i had been using the set all day with out a break. while i had the set on it stayed in thx mode. Im just trying to get a better understanding of what exactly is happening here. Im sure if my terminology is incorrect or my tech speak is off someone will be happy to jump in and correct it, but the general point still stands. could this be causing the black levels to appear lighter?????????????????
I think something like that would probably be the theory behind the gradual changes over a longer period of time (like people's experiences with some of the earlier model lines). It wouldn't explain away my issue though (doubled within a week and a half at ~350 total panel hours).
anyway i left the set off for a while and then turned it back on and the lighter blacks were still evident, so i guess there went that genius theory i came up with..
