You could try showing the tech what it looks like when you switch from a no input screen to an input with a 0% stimuli test pattern or black image from an HTPC or thumbdrive, if you have that option.
If I'm understanding the issue correctly, the most dramatic way to demonstrate the mll increase would be to set up a properly working G10 next to yours and simultaneously switch them from a blank input to one with a black image. If it's the case that your blacks don't get any darker than they are on a blank input screen, the other G10 would drop down to the normal mll while yours would stay the same.
I know most people don't have spare plasma TVs laying around for test purposes but if you could set that up somehow I think a technician would have a tough time arguing that there isn't something wrong with your G10.
If someone volunteers to check black level on my TV you are welcome
