Originally Posted by Meteor|WAR
Ok, here's my result from HCFR. Referred to this guide to set up the i1 LT. Meter warmed on the TV for 30 minutes, then calibrated it in the dark with a black DVD case. Reading taken in pitch black room, 0 IRE pattern from AVS HD 709 Blu-Ray on a PS3...
ftL: 0.017
TC-P46G10
May 2009 build date
1359 hours
FW version 1.29
THX fix installed
No A-board replacement
i1 LT meter used
Unfortunately I don't know what the ftL was back when I first set it up as I only just got the i1 LT. I however cannot perceive any change in black level by looking at it. FWIW I am still very happy with my G10.
ftL: 0.017
TC-P46G10
May 2009 build date
1359 hours
FW version 1.29
THX fix installed
i1 LT meter used
Can you tell us what your brightness is set at, too?
Kevin
It is all too convenient for Panasonic to have low MLL at review time and higher MLL after normal usage when you factor in their own admissions. And yet people still bend over backwards and jump through hoops in order to be 'scientific' about this. As if that changes the known facts already in front of us. Is it just a happenstance that new Panny BL looks like older Panny BL after normal use? Where did the Black go? Why was something clearly known by Panasonic to be temporary touted as a selling point? It is deceptive on its face and no amount of "this is only a screw up in the voltage adjustment" can change that. Everyone knows Contrast ratio claims by manufacturers are to be taken with a grain of salt. Panny has simply elevated that to rock salt.
