Originally Posted by xhonzi
Also:
The Panasonic format seems best as long as you can get the 48 full frames per second to fit on the disc. How much space does a typical 2ish hour movie take? Is there extra space on the disc without having to sacrifice? Will the spec need to also support tri-layer-75 GB discs or quad-layer 100 GB discs? Seems like you might as well, as long as you're breaking the mold and need new players.
As far as the 2D version goes, I assume that can just be on a different disc much the way they often do anaglyphic movies today.
Also:
The encode will be either 1080x24P or 1080x60i:
http://www.nabanet.com/nabaweb/docum...P1_PFannon.pdf
Using MPEG4 AVC MVC - they can extract a 2D version from the 3D encode. One single version of the movie
