AVS › AVS Forum › Audio › DIY Speakers and Subs › Can you smell what Brando's cooking!?
Can you smell what Brando's cooking!? - Page 12
post #331 of 603
tsloms> No progress as I was concentrating on getting the No Quarter ready for RMAF today. Once work slows down at the end of the month I'll finish the BBV2
Penn> I haven't read much, but with the downsides of reducing gain for the DSP I suppose there would a preferred method. What have you read?
post #332 of 603
How is RMAF? I will you be posting any opinions about RMAF and will all the great speakers that are there?
I have no definitive answer, different threads have discussion on how changing the gain takes up processing power and therefore maybe degrades the SQ....I have no idea really and I never put a lot of effort into figure things out. I do know that many over on DIYAudio suggest using external volume controls to maximize the SQ.
post #333 of 603
Here are the current filters listed as the exact values. With the DCX I had to pick the closest available values. Shelving filters list the DCX correction since they calculate the F0 a little different than Soundeasy does.
Tweeter:
Gain: -13.5 dB
HP: BW3 @ 1120hz
PEQ: Fo 2400hz, Q 3, Gain -3
PEQ: Fo 940hz, Q 2.5, Gain -5
6dB Shelf: Fo 10000hz, Gain 13.5 (DCX Fo 20000hz)
Woofer
LP: LR4 @ 1670hz
PEQ: Fo 4360hz, Q .4, Gain -14.8
6dB Shelf: Fo 100hz, Gain 3 (DCX Fo 88hz)
Any info on delay settings?
post #334 of 603
Brandon, how'd it go last night?
post #335 of 603
Jon Marsh posted a good comment about Brandon's NQs on HTGuide.com
post #336 of 603
We probably only played three songs on the No Quarter and Jon's NeoD. Very good comments from the guys on the No Quarter, especially Tom but I think he'd had some wine by then We never really had a chance to crank them up and I didn't get to hear Jon's Ardent either RMAF left me unimpressed with the same spartan music that makes everything sound decent, but nothing really impressive. Coupled with poor room and setup it's hard to make any judegments abotu anything I heard that day, other than some speakers showed promise and a coupe were offensive, with a bunch in between that were just mediocre. The most promising designs were the JBL S9900, Revel Ultima Salon2, TAD Reference One, and the Wilson Beneasch (sp?), and speaker from a little builder called Intuative Audio. GR Research's open baffle was a little spitty, and the Audio Physic open baffle was just plain harsh. Listened to the MBL omni and once again was astounded by how that much money and engineering can result in such an offensive sound. Listened to an open baffle Lowther field coil and I still don't "get" the fullrange fascination. So pretty much a day of half starts that left me with more questions than answers.
At Tom's we only had a short time to listen to music. To be honest I've come to sort of dislike the room we have the auditions in. It seems to make everything sound small and dull. Even the NeoD, which I know certainly would not be the case in other rooms, given the drivers' dispersion characteristics. I have a particularily live room, but even speakers I've played at friends' homes has sounded much more like my room than Tom's. I wish we could use his HT room, but that has monster line arrays that just aren't feasible to move.
The DE160 is a much smoother driver than I expected. No sibilance or spittiness that some domes get when pushed even reasonably hard. I think proper aiming is going to be much more critical for soundstage and spaciousness than a conventional speaker. At my house the soundstage is pretty much the same as my Delphi's which are similar to the NeoD in using small, wide dispersion drivers. But my room is pretty reflective. I want to try the setup in the JBL trailer with the S9900 which are spaced far apart but aimed directly at the listener. Sounded like big headphones. I'd also like to cross them in front of the listener ala Geddes. Anyway I think they will require more optimizing due to teh directivity than conventional speakers.
post #337 of 603
augerpro, how do yours compare with the s9900's?
post #338 of 603
I only heard 2 songs on the S9900 so there is no way I could speculate on tonality or response smoothness from that (compared to mine). Soundstage differences were probably mostly setup related, the JBL were widely spaced and pointed directly at the center seat, while the one hour I had the NQs running in my house I just pointed them straight forward. Still a very good soundstage and spaciousness, but as I said I have pretty refelctive room. I will say that the JBL drivers seemed very well behaved. We didn't crank them up, but there wasn't even one hint of anything offensive. Driver integration was very good, I couldn't really tell where one driver took over. I would have liked to had a lot more time with the S9900 and TAD Ref One. Under identical conditions I would imagine both would pull ahead of my speakers quite a lot, but then again they should.
BTW the TAD does seem to have done a coaxial correctly. The cone is very shallow, almost looking like a tweeter on the MCM waveguide, if the waveguide was silvery and made from Be.
post #339 of 603
lol mr. a., the jbl's cost 50x more than yours. reading between the lines, i get the sense that nothing jumped out as being immediately and obviously superior in the s9900's. that is really a testament to your work. thanks for reporting back.
post #340 of 603
Augerpro, would you rate the no quarter's as capable of rock concert spl's?
post #341 of 603
I don't know about rock concert levels but they can get louder than anything I've built so far. By a large margin. In fact I don't really know how loud they will acceptably go. I played Queen's Fight From the Inside last night at 102dB (RS meter, C, slow) at the listening position (13 feet) and it was incredibly loud. Regardless of what the math may suggest, there is no way my other speakers using the Peerless Exclusive 8" would have reached levels like that. The NQ's were rocking alright...
post #342 of 603
So the hiss has been dropped to acceptable levels by switching to XLR for the tweeters, then reducing the amp's gain while raising the DCX output gain a corresponding amount. I also raised the DCX input gain.
I wanted to do some research to see how high the woofer could be run, and if there would be any improvement to the tweeter by raising its crossover point, so I modeled a 2khz crossover design also and input that into the DCX. Unfortunately in the time it takes to get up and change the DCX back and forth I pretty much forget the fine details of what I've heard so nothing to report yet. I've found there is nothing like instant switching to get an unbiased comparison of speakers so I'll try this again when I can get my laptop hooked to the DCX and can change instantly back and forth while sitting on teh couch.
BTW here are some pictures of my listening room. It has a very spacious sound but without any major defects that you might expect from it being so reflective. This room is the main reason I agree heavily with Toole. If I were to use room treatments it would be solely for frequencies below the Schroeder F, I like my reflections thank you very much I've found that I usually tip the treble down a bit from the modeled flat response in most speakers I design (which has occasionally caused issues when someone built my design or borrowed my speakers and played them in a treated or "dead-ish" room). Interestingly I've not had to do this with the NQ. They have not been tweaked from the model which was as flat a response as I could get. I think this is mostly due to its directivity.
post #343 of 603
Thanks for the update and the pics!! Love the stands
btw, did you try and use the Store and compare functionality?
Also, I have read many times and probably been told more then 10 times to increase the gain to the DCX to improve its performance. I finally picked up a Panasonic SA-XR55 to be used a volume control, it will sit between the DCX and my amps (which have no gain controls).
I still also want to spend the $500 and "upgrade" one of my DCXs with unbalance input/outputs with consumer level gain structures instead of the pro level ones the DCX has. That upgrade should also give a better noise floor/SQ.....so they say.
Im just holding off on all purchases for now as a promise (and Bet) with my wife
btw, I follow your thread over on HTGuide also and Im extremely curious to what great suggestions Jon Marsh will have wrt your crossovers. I hope that discussion is public so I can continue to learn from all things you and others do.
I forgot to mention, those speakers LOOK awesome!!! I can not wait to finish mine but family and travel is in the way for the next month or so.
post #344 of 603
Does the SA-XR55 have preamp outs? I have the SA-XR50, it doesn't.
post #345 of 603
Yeah I stored profiles in the DCX and it doesn't take but 10 seconds to get off the couch and switch. Still though 10 seconds is a long time for accurate aural memory and I prefer using some sort of instant switching whenever possible.
post #346 of 603
Its still in the box but yes the specs say 6 preouts.
post #347 of 603
augerpro, how are you coming along with the passive design of the crossover?
post #348 of 603
Erm, I'm afrraid the XR55 has no pre-outs. Just the 5.1 inputs.
post #349 of 603
Yeah, I noticed that when I had it out on Saturday.
I already ordered the NHT volume controls.
post #350 of 603
If you want unbiased, get someone else to do the switching who will not tell you what you are listening to, or even tell you if they actually made a switch. I think a ten second pause in between is a ideal. By not knowing if a switch is made, you will not expect to hear a specific change. You may instead expect it to sound the same, because you guessed that a change wasn't actually made. You will have to rely on what you hear instead of what you think you should hear. Or as an alternative test, have someone rename the two crossovers, and save both of them with two different names. Then you can compare all four of them, but you will not know what to expect.
post #351 of 603
Originally Posted by catapult View Post
The sides are tapered so moving it forward would leave gaps at the sides. You could make it work but it would be a kludge.
post #352 of 603
Here's a picture of both cabinets, ready for crossover test and design.
If the time delay cannot be accomplished in a simple analog circuit, I may have wasted a bit of time. We shall see!
post #353 of 603
Nice job, Jack! What did you do to move the baffle forward?
post #354 of 603
The standard cabinet had slots top and bottom to mount the baffle mounting rails. I mounted them as instructed, but cut a 3/4 inch spacer which was glued and screwed to the front edges of these mounting rails. Then the side mounting rails were glued and screwed to match the forward edges of the spacers. A new baffle was constructed by gluing a 3/8" piece of particle board to the back of a 3/4" piece of MDF. The front of the new baffle then is even with the sides of the cabinet .
post #355 of 603
The horn will be a real gem in the QSC PL-000446-GP that only costs $8 and is obviously designed using Geddes' principles.
Apparently supply is going down or demand is going up (or both?) because they're now $12.50
post #356 of 603
Time to order 10 more Before they go up more or stop selling them.
post #357 of 603
Are you going to make hats out of them?
post #358 of 603
I ordered 4 of the No Quarter horns and 3 of the SC1250 horns. One of them is out of stock till 12/2/09 and I think it's the NQ horns.
Using NQ's for surrounds does seem a bit excessive. We'll see if I actually do that or not.
post #359 of 603
Brandon,
Sorry for the silly question but are those ports are the side of the cabinets in post 342? Thanks.
James
post #360 of 603
Nope, speakers for friends and family
