Hi all! This is my first post to the forums after lurking for quite a while and doing research.
I'm actually going to be moving to HDTV from my current Sony 27" CRT and have managed to narrow my choices to either the Samsung PN42B450 plasma vs. the Toshiba 40RV525U LCD (40-42" is more than big enough for the room it's going in). Prices seem to be similar for both, so that's not an issue.
My main question is: which is better for my usage scenario? I'm planning on converting my PS3 into a MythTV frontend, with the source being OTA HD (with some games like Rock Band and various racing/FPS games thrown into the mix); currently I'm recording and playing back a few shows that are broadcast in HD, so hopefully there won't be too much 4:3 content from the air. I'll probably also need to plug the TV into a PC 5-10% of the time, as well as into a 5.1 stereo receiver without optical audio input (which is why I eliminated the Panasonic plasmas from consideration). I also imagine I'll start wanting to watch Blu-Ray as well, since I'll now have the technology to take advantage of it.
Anyways, thanks in advance!
I'm actually going to be moving to HDTV from my current Sony 27" CRT and have managed to narrow my choices to either the Samsung PN42B450 plasma vs. the Toshiba 40RV525U LCD (40-42" is more than big enough for the room it's going in). Prices seem to be similar for both, so that's not an issue.My main question is: which is better for my usage scenario? I'm planning on converting my PS3 into a MythTV frontend, with the source being OTA HD (with some games like Rock Band and various racing/FPS games thrown into the mix); currently I'm recording and playing back a few shows that are broadcast in HD, so hopefully there won't be too much 4:3 content from the air. I'll probably also need to plug the TV into a PC 5-10% of the time, as well as into a 5.1 stereo receiver without optical audio input (which is why I eliminated the Panasonic plasmas from consideration). I also imagine I'll start wanting to watch Blu-Ray as well, since I'll now have the technology to take advantage of it.
