Hi All-
I am still debating upon a new receiver and have narrowed my search down to 2 models- the Elite SC-25 or the Elite VSX-23TXH.
The receiver will need to drive to Sonus Faber Grand Pianos (Concert Home Series). I think it is pretty much a no brainer that the SC-25 will provide plenty of power- but will the VSX-23XTH provide enough horsepower, or will i be disappointed?
Here are the specs for the 23TXH
110 Watts x 7 Direct Energy Amplification
(20Hz - 20kHz, 8 ohms, 0.09% THD - FTC)
Here are specs for the Grand Piano's:
Type: 30 litre two-way with ABR front vented design, magnetically shielded
Tweeter: 26mm silk dome ferrofluid cooled
Mid and Bass Driver: 180mm fibre glass multi-coated cone
Frequency Response: 35Hz - 20kHz
Sensitivity: 90dB/2.83V at 1 meter
Nominal Impedance: 6 ohms
Crossover Frequencies: 200Hz, 3kHz
Maximal Power Handling: 250 watts
Dimensions: 1080mm x 235mm x 290mm (HxWxD)
Weight: 25kg each
Any help appreciated- Thanks all!
Weight: 25kg each
