Hi,
I have been searching for a while and had trouble finding the basics of building a tapped horn or folded horn subwoofer. I have a few questions, any useful links would be appreciated or anyone with experience in building them please add some light.
1. What is the key difference's between a tapped horn or folded horn subwoofer?
2. How do you model them? or what is the best way to model them? (step by step approach would be good)
3. Is the sound quality of a properly designed folded or tapped horn subwoofer less or better or equal to a bass reflex cabinet?
4. Are specific drivers better than others when it comes to using them in horn loaded subwoofers.
If I can get these questions answered, I will be willing to make some saw dust.
That sort of thing just don't go around here...where's the fun in that? Seriously though for me the problem is nobody has done a build that I'd want to copy yet.
I think in branndon's GTG, the TH-50 was "pulled back" as things were falling off from the shelves in the room, rather than them hitting the limit.
