Originally Posted by
Rl3058
I wrote Panasonic about the problem I was having and their response was:
When playing the movie insert a 1GB SD card in the unit and it should
allow the movie to play. Make sure that the card is no less than 1GB.
Hmmm....I DO have a 1GB card in the SD slot, and I am having the same problems that others have described.
FWIW, my Panny 35 has been great. This new
Stargate is the first BD I've had any trouble with.
Edit: OK, I have tried the various suggestions above. The only thing that works is
removing the SD card during playback. BD Live on/off has no effect. Having the SD card "in" causes the playback to stop after the trailers. I suspect it has something to do with the BonusView authoring on the disc not playing nice with the Panny's f/w.
I confirmed this after
reinserting the SD card once playback had successfully begun, and attempting to activate the pop-up menu which utilizes PiP (BonusView), and experiencing player freeze up.
