AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › NEED help with downloading break in dvd
post #1 of 3
hi, i downloaded the iso file and i need help burning it to a dvd .i have never burned a dvd before . i am using windows vista .i downloaded the file the zipped file and than i clicked on it and extracted all files than what do i do? thanks alot.
post #2 of 3
Download some dvd burning software or your computer probably came with something if it came with a DVD burner. With most DVD software all you need to do is drag the .iso file into it and it will start burning it.
post #3 of 3
YMMV. Some merely transfer the ISO file onto the blank DVD. I'd suggest Image Burn for a freeware option.
http://www.imgburn.com/
-Pedro
