Originally Posted by madshi
(1) When the brightest pixel in a frame asks for 100% brightness, the DI is turned off completely for that frame.
(2) When the brightest pixel in a frame is less than 100% brightness, the frame is remapped (basically it's artificially spread so that after the remap the brightest pixel shows 100% brightness again) and the DI closes down accordingly.
If you can, read Greg Roger's review of the Planar in which he describes how its DI works. It is similar to how you describe.
(you walked right into that one).
I hope the "VW90" (or whatever its name will be) will be great. Even if it only serves to put more pressure on JVC. We'll have to wait and see. But what I meant was that going from VW50 to VW60 to VW70/80, native CR has improved. So having a DI hasn't stopped Sony from improving their native CR.
). Even then, if the 950 had higher ANSI contrast, that'd be true icing on the cake, and it'd be my choice for my homecinema.
