It's been a while since i poked my head into the subwoofer forum.
I know there is a poll for this but no thread so i thought before tinkering with my SMS-1 and subwoofer i would ask here. I have an SVS-PB-12-Plus/2 Subwoofer hooked up via the SMS-1. I have just upgraded the firmware for the SMS-1 after almost a year of meaning to do it. It's been a few years since i last had a stab at calibrating it using the SMS-1 and Avia and a sound level meter but it's in need of calibration again.
I have two ports blocked on the subwoofer and it's set to 16hz on the subsonic filter knob.
First off i wonder if any opinion can be given on having two ports blocked. Should i go for the 20hz option and just one port blocked or leave it the way i have it ?
Concerning the SMS-1....I bought it because the room had a few peaks in it. Am i right in thinking it's better to lower the peaks rather than to increase the other frequencies to compensate for these peaks. I read somewhere that it's best to lower by 3db maximum but the SMS allows for a lot more than 3db. Does lowering peaks have any negative effect ?
Should i get the line as flat as possible with no humps whatsoever or should i add a house curve at some frequencies. Now i know i could try it out but i would love to hear opinions on this.
I will be using a pretty cheap digital sound level meter from Radioshack which is now about ten years old and my concern is when using Avia test tones i'm not sure how accurate it is once you get down low. Do i compensate for the lower frequencies in some way when using a sound level meter ?
I'll be crossing over at 80hz and setting all speakers to small but i always seem to have a problem at the crossover point as i'm unsure how you get it precise and spot on so all speakers match. How do other people make sure it's a smooth transition ?
I think i'm right in saying the subwoofer should be 10db higher than the other speakers as thats how they are at the cinema. It's just getting that 10db higher all the way down to 20hz that is troublesome due to the sound meter probably not being accurate that low.
I watch movies on Blu Ray only these days.
