You can also use that 3414 as a preamp with a remote power supply. This way you can place the amp at the antenna, and have the power supply inside near the TV to help avoid signal loss. PCT store sells the remote power supply, also Amazon. But it may work for you as a dist amp as well. It is a good amp.
post #31 of 39
7/20/12 at 5:58pm
