Originally Posted by schmezzy
I'm quite happy with the new screen. The gray tint provides a better ambient light picture then Killz2 or BO cloth did, and I do not seem to have lost anything in gain (and may have even gained). I will be upgrading projector soon for more lumens, probably to a 8500UB, in which case I may go darker on the gray tint for a better ambient light picture. I had done research on metallic mixes, etc. but this performs so well I won't bother experimenting with others unless I find myself with time on my hands.
Schmezzy
Thanks for writing an excellent and informative post. And with only 4 posts to your credit in 4 years I'm very tempted to go read the other three. Your experience with white, gray and enhanced sheen levels thru the careful addition of poly, and doing visual verification as the test of what you wanted to achieve, is exactly the same method several of us have followed with similar results. Thanks for adding to the data pool for others to build on.
As to comments made to disparage this method or point to its limitations by others, I don't think some people will ever understand the physics of reflected light coupled with the anatomy of the human eye and brain working in concert. Who cares if BOC is 1.0 or .85 in its reflective index. You pointed out that you were guessing not measuring, and more importantly you were comparing and explaining that comparison. Most people don't have a calibrated block of calcium carbonate or whatever they use to establish unity gain, but do have an idea of what BOC looks like projected to and your even better comparison was the Kilz primer.
The bottom line is you are now getting a level of returning foot lamberts to your eyes that is acceptable and producing a pleasing image. You are doing that while maintaining better ambient light performance than before, and have reached a point where your performance has exceeded your desire for ambient light. In doing so with a simple method that required minimal tools and equipment and skills most DIYers would feel comfortable trying. You even pointed out that you have done wall painting in the past and like many of us have found the poly seems to add an ease in getting the paint to level and smooth out, as long as the method of maintaining a wet edge between passes is done.
In your future you mentioned more lumens and most likely a projector capable of better CR. Both of these things should benefit you with this same approach, and yes possibly a darker screen. The idea that you couldn't tailor this method to a better brighter projector without hot spotting is balderdash.
Once again thanks for a great post. Enjoy your screen, and looking forward to your next post in a year or so..
