AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Need Help with Bejeweled 2
post #1 of 4
OK all you bejeweled 2 fans out there, any way to get a mouse to work with this game?
There are two trophies I can't get. One of them is to complete level 5 on action mode and the other is to have 5 hypercubes on a single board. I guess I'm not smart enough to figure out how to get the 5 hypercubes on a board. But I think if I can get a mouse to work in this game, I can get past level 5 on action mode.
Any tips would be much appreciated.
Mike
post #2 of 4
the app either supports the mouse or it doesn't.
post #3 of 4
Can't help you with the mouse question...
Those two trophies were my last two, also, and real pain! For the five hypercubes, use classic mode and when you do get a hypercube, try your best not to use it or blow it up. It will roll to the next screen if you finish the level, so you can keep going. Once I figured this out it took me two or three tries and I got it.
The action is half skill and half luck. Try to get a hypercube and use it if the timer goes below half, but try to get it to roll to the next level if possible. Once you get to level 5 if you don't clear it out within the first 10 seconds you are toast. When I won I had two hypercubes rolled forward from level four and I used them both right away.
Have fun!
post #4 of 4
Have fun!
AHHHHHH!!!!
I didn't realize the hypercubes roll over. Awesome. Thanks for the tip Jeff! That will definitely help with both Trophies.
  Back to Forum: PlayStation Area
