Anyone who has a vizio tv, particular a vizio va19l should really consider the difference between a good picture and a better one. Users must consider the amount of contrast, brightness, and color put into the picture. The backlight should never be to high or to low. If your a person who is technical when getting the most from your hdtv, then my settings should be useful to all you that have a vizio tv.
backlight=70
brightness=48
contrast=30
color=35
tint=0
brightness=48
color temp=cool
Never turn on the advance settings, i have found these settings to disturb the natural look of the picture. the contrast is at 30 because i have found it to be a bit similar to the backlight. When the contrast is high is creates a flicker in images that has white lines, also a sort of distortion in the background. To much color creates bleeding. The brightness should be treated with caution. When the color temp is at cool it makes the image look peaceful.
There is much more i should say, but i want to know if any of you out there think what i'm saying is right, or have actually put it too the test?
backlight=70
brightness=48
contrast=30
color=35
tint=0
brightness=48
color temp=cool
