Originally Posted by rehaz1
I have all of my devices assigned to the Blaster, including all that are in line of sight to the remote like the TV. I never have to worry that a command might be missed if someone or something walks in front of me ans the remote. And it also works great with the Sleep timer, if the remote should fall on the floor, the devices will still turn off.
I hear you...makes perfect sense - thank you!
Where did you buy the y-splitter from and are you using a 3rd logitech blaster or 3rd party? Is there a way to check compatibility with blaster and my Samsung TV or is trial/error...?
Again, many thanks!
