Originally Posted by bryansj
With Eventghost you can just pick any remote from the Logitech profile such as an early 80s model VCR. The USB-UIRT will receive the signal and Eventghost will map it to the command of your choice. Hit Power on the remote and tell Eventghost to map it as Power. You can even map Record on the remote to do Eject on the PC. I assume the USB-UIRT entry in the Logitech software is just some sort of remote with a lot of commands. When it asks for the power button just pick something and map it to power in Eventghost.
That's the thing though, there isn't anything to pick, it is a drop down box that only has one item in it 'no option'. In order to give it an option, I have to teach the logitech software IR commands which I can't because I never had a remote for my PC.
So I'm kind of at a loss. I am hoping someone has this sort of setup and know how to solve this. It sounds like my only option right now is to buy a MCE remote or something that will control my PC and then teach the harmony, but there's just got to be an easier way than that.
