I've been reading about (or trying to anyway) dithering on plasma televisions but I'm not really clear on some things. For example, when someone says dithering are they including the "flickering" of the individual sub pixels to vary the intensity, or are they truly talking about old-school 16 color image style dithering where you mix the colors into, say, a grid (of course the real algorithms would be much more complex) to get a color in between?
More importantly, exactly how many intensities can a single sub pixel produce on a modern plasma, and does this vary significantly from model to model? Panasonic claims the V10 series can do 6,144 "Shades of Gradation" but then it also says "equivalent" .... what the heck does that mean?? And where does this number come from it seems way to high to be real...
To me, anything less than 256 (ie 8 bits per channel) would be completely unacceptable. Granted this is based more with experiences with dithering in other places (eg printers, pre-24 bit color displays, etc) but if you ask me even 256 shades is not enough as I can see the banding clearly on a single color ramp, so if the dithering plasma does is to defeat this, then that's a great feature... if its to overcome the inability of a single sub pixel to produce a sufficient number of intensity levels ... that's not so good.
I need to drag some test patterns into best buy and convince them to let me look at them regardless of the answer to this question, to see just how good/bad it looks, but I have a hard time believing what would essentially be a less than 8 bit display could look good in situations with smooth color ramps...
As a side note why can't the companies just release the real information for things like this. I mean I can understand things that can be measured in different ways eg contrast (though even that has a standard they SHOULD be using) but there is no real fudge factor in how many shades a sub pixel can produce so why not just come out and say it?!? Also display input lag, that REALLY needs to be a listed spec its not hard to measure, and in fact most of it they know about before they even begin building the displays since its based largely on how many frames the various processing routines they are doing need in advance... argh picking a new tv is turning into a major headache.
