I wanted to put my OTB RGB graph (before) and the corrected RGB graph with what offsets were done to fix them.
[I have also done a before and after in the A-Board thread using those A-board values]
Then compare it using someone else's 50V10 with build dates before June 2009 and after August 2009. If anyone has such a set and has measured OTB RGB graphs, please pm me with a link to the said graph.
Mention your
- build date
- pref approx hrs of usage at measurement
- Picture mode
- Before RGB image URL
- Offsets
- After RGB Image URL
I will then update this post to try and visually demonstrate why I think offsets are not working for some. I personally believe (as I am trying to prove/disprove) that all sets come out with different RGB's and some have more significant deviation than the mean. Mine was significantly off for blue. On some sets, if my offsets were used, it could make theirs look too blue. The offsets between Cool > Normal > Warm should be the same factor on all sets. But the base for (some of ?) these sets *seem* to have variations that matter.
I want to show ONLY OTB RGB graphs and TEXT values of their offsets required to correct them to observe what the pattern is.
Audiotitis
50V10, June 2009, FW 1.28, Measurement at approx 900 hrs.
Custom RGB OTB
R Cut = 80 Orig = 80 [Delta = 0]
G Cut = 7F Orig = 80 [Delta = -1]
B Cut = 7F Orig = 80 [Delta = -1]
R Drv = FC Orig = FC [Delta = 0]
G Drv = E6 Orig = EA [Delta = -4]
B Drv = B4 Orig = 80 [Delta = +52]Custom RGB Corrected
