AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Sammy LN46B750 or Panny Viera TC-P50G15
post #1 of 3
Im looking @ the panny TC-P50G15 or the sammy 50-B650 or B750 . I am moving up from an old sammy LN-T4061-60Hz. I want to go plasma this time but am looking for some insite on these 3 units. Some info first, we sit 7'-8' from our display,the room is quite bright during daytime but no direct sunlight on the screen, we are BluRay freaks, lite gammers, also would like to use this display as a pc monitor from time to time. Any recomendations would go a long way about now.
Thanks in advance; manforditis
post #2 of 3
Well, the only thing that caught my eye, was the "use this display as a pc monitor from time to time". About what percentage of the time would you be using it this way?
And the since Sammy LN46B750 is an LCD, you may not get to many votes for that here.
post #3 of 3
Thanks cleh19, from time to time! don't know for how long though, each time.m/b 1hr m/b less?? Sounds like this could be a problem on plasmas???
