so im to the point where I need to hang the side surrounds off the walls. I tried to pre-plan this as best as possible by putting a horizontal 2x6 near the wire connections.
turns out i should have done more....
Im trying to wall mount Paradigm ADP-370's using the supplied hangers, however it appears that one speaker will not be aligned properly to the wood.
What have you guys done in situations like this?
