AVS › AVS Forum › Video Components › Home Theater Computers › Dell Zino HD - New mini HTPC
Dell Zino HD - New mini HTPC - Page 8
post #211 of 5037
Originally Posted by lawlen2 View Post
Hi, I have a Shuttle X100 as my htpc, currently. I can't play 1080p due to the ati x1400 video card that it now uses. Is the 4330 in the zino a MXM II card? I use two WinTv usb 950q as my two tuners. Can I use them on a Zino with an external usb hub? I ask because of the IR and bluetooth usb devices I use for the remote and the keyboard-mouse.
Yes, the 4330 version is an MXM card that is plugged into the bottom side of the mobo.
I don't see any reason why you would not be able to use your 2 tuners, however, I did not test with a usb hub. I would fully expect it to work though.
post #212 of 5037
Java Jack - Not sure if I saw the question here or in TGB, but someone asked if the Zino HD would work with the ATI Digital Cable Wonder. I am now leaning towards two of these (6850e CPU + 4330 GPU + Windows 7 upgrade). My goal is to upgrade my main machine with an internal multistreaming card (when available) and than take the two ATI DCT's that I have and connect one to each so that it can have live TV functionality.
Do you have any way to test with the DCT?
post #213 of 5037
the Zino HD does look intriguing. although lossy 5.1 across HDMI is a nice touch i'm keen to see whether the dual-core Neo is sufficient (without hardware assist from the 4330) to playback 1080p content.
post #214 of 5037
Not at the moment. However, I think I can get my hands on the verification tool and run it on the Zino HD and make sure it meets the requirements.
post #215 of 5037
Even the base model comes with good hd hardware acceleration, so why do you need the neo to be fully capable on its own? The stickler with most of these low power machines has been playing adobe flash HD content.
post #216 of 5037
Probably because he wants to run a front end that does not have h/w acceleration support at the moment.
post #217 of 5037
I guess the specifics of how it compares to Zino's AMD platform is irrelevant though if vendors like HP/Dell aren't going to design/build CULV-based platforms outside of the laptop market, or if Intel isn't going to design/build a mainboard solution :-(
Originally Posted by ilovejedd View Post
I'm still not sure whether the Intel CULV processors are soldered or not so aside from the seemingly OEM-only availability, that's another catch for DIYers.
However, the GS45 chipset paired with the CULV processors can certainly support dedicated graphics. Needless to say, that tends to increase costs. The ASUS UL80VT & UL50VT both have NVIDIA G210M graphics cards. You can switch between the integrated Intel 4500MHD for longer battery life or the NVIDIA G210M for faster performance. It also has an overclock feature (Turbo Boost) that allows both cores of the SU7300 to go up to 1.7GHz or a single core to 2+GHz. The HP dm3t has the option to upgrade to an NVIDIA G105M. In both cases, you just have to pay for the privilege as the laptops end up costing around double the price of a cheapie Acer or Gateway CULV.
Also, it should be noted that Intel's CULV processors are not cheap. The 1Ku cost of the Celeron SU2300 is $134 and the GS45 chipset is $53. I'm actually amazed that Acer's AS1410 only costs $400. Dell's Inspiron 11z starts at $449 and that model only has a single-core Celeron 743 which should be roughly equivalent to the base Zino HD's Athlon 2650e. The only thing detracting from the Zino HD's appeal is the $40 shipping charge. I think the upgrades most people are considering are:
Windows 7 HP +30
3250e +60
6850e +110
HD4330 +75
Those bring up the cost of the unit to $319~$444 making the shipping charge an extra 9~12% increase.
post #218 of 5037
I wonder if the same applies to the Athlon CPU's available to the Zino?
Not all of them seem to use the Neo nomenclature, which I believe is soldered.
Originally Posted by candre23 View Post
They're soldered on. All the CULV processors use the BGA956 package, which as the name implies, is a BGA arrangement.
post #219 of 5037
Intel's on track for the IGP+CPU+Mem controller to be ready for early next year I believe. See one of the positing from the last few days in Engadget or try Ars. It'll be for their lower range CPU/Mobo chipset. They'll still have their higher-end CPU's/chipsets with no IGP on the CPU die.
Amd is talking about putting the cpu and gpu all on one piece of silicon with "bulldozer," but not until 2011. Thats when things will really get good for us HTPC guys. I believe Intel is on about the same time schedule with their sand-something.
post #220 of 5037
Sure maybe from a Windows perspective,
But it's murkier from a Linux perspective for those that want to use one of the Linux-based media frontends projects :-(
That's good news. It certainly puts the Zino head and shoulders above any of the ION nettop offerings.
post #221 of 5037
Try Linux Boxee/XBMC/Myth please!!!
Unfortunately I don't think AMD's XvBA is really there yet compared to VDPAU.
So it may be somewhat of a dud experience compared to Windows Boxee/XBMX/Myth :-(
Originally Posted by Java Jack View Post
I was thinking about that the other day. I think I may use this for a series of blogs on XBMC, Boxee, and a Myth TV or Sage TV implementation. Not sure if it will be one blog or a few...I know that people have been doing stuff like that with the Mac Mini, it would be interesting to see how well those might work on the Zino HD.
post #222 of 5037
Mmmm MXM....
Is anything soldered down in the Zino like apple have now 'suckily' done to Mini's or are you free to swap most stuff out?
post #223 of 5037
Originally Posted by jalyst View Post
Mmmm MXM....
From an architecture perspective, CPU is socketed. HDD is 3.5" SATA. ODD is slim line tray load SATA. Wireless N looks to be a PCIe x1 mini card slot, Memory is SO DIMM and graphics is MXM.
My current box does not have the MXM slot on the bottom of the board so I think there may be 2 board designs, one with graphics, one without.
Now, you would need to talk with Dell about swapping stuff out on your own and any impact to warranties, etc.
post #224 of 5037
$444 (6850e CPU + 4330 GPU upgrade) - 1080p h.264 blu-ray rip / MKV playback, 720p streaming flash video, 7.1 LPCM and 5.1 AC3/DTS over HDMI
The value doesn't seem very impressive to me. One can get an Acer AS1410-2285 that I understand will do everything you listed above -- except for maybe the 7.1 sound (which is highly overrated) -- for just $400, and with it you also get the additional functionality of a notebook.
post #225 of 5037
For those looking to equate pricing with capabilities, it breaks down like this:
$289 (3250e CPU upgrade) - 1080p h.264 blu-ray rip / MKV playback, 480p streaming flash video, 5.1 AC3/DTS over HDMI
$339 (6850e CPU upgrade) - 1080p h.264 blu-ray rip / MKV playback, 720p streaming flash video, 5.1 AC3/DTS over HDMI
$364 (3250e CPU + 4330 GPU upgrade) - 1080p h.264 blu-ray rip / MKV playback, 480p streaming flash video, 7.1 LPCM and 5.1 AC3/DTS over HDMI
$414 (6850e CPU + 4330 GPU upgrade) - 1080p h.264 blu-ray rip / MKV playback, 720p streaming flash video, 7.1 LPCM and 5.1 AC3/DTS over HDMI
Add $100 to any configuration for an actual blu-ray drive.
Sorry for bringing this back up again, but I'm hoping to pull the trigger on this one today :-)
We're sure that the 6850 with the bult in video option definitely provides 5.1 audio over HDMI? I know the 4330 won't make a difference with the 720p flash streaming and just want to confirm I don't need it for normal 5.1...
post #226 of 5037
According to Java Jack, yes.
You don't get an optical drive, or a form-factor which is convenient for HTPC purposes. Also, without some evidence, I have a hard time believing the SU2300 will do smooth 720p flash playback. For an accurate comparison, the configuration most similar to the Acer 1410 is the $289 one.
post #227 of 5037
So is there anything groundbreaking/next gen about the Dell, or is it just more the fact that they managed to get desktop parts into a small case at an affordable price?
post #228 of 5037
The processors are brand new. I think one of the single-core chips is available in a version of the MSI Wind, but other than that, the Zino is the first device to offer them. I don't know if that counts as "groundbraking", but it's something.
The rest of the components are nothing revolutionary. It is a lot smaller and cheaper than any pre-built HTPC with similar capabilities. Previously, the only options were either small, cheap Atom/ION boxes (which cannot handle HD Flash or any CPU intensive tasks), or larger, more expensive boxes with desktop components. Even the 6850e is nowhere near as powerful as even a low-end desktop CPU, but it is fast enough to do everything you might need a HTPC processor to do.
post #229 of 5037
Not comparable. For one thing, the 6850e is a better processor. Needless to say, the 4330 is also better. Config that most resembles the AS1410-2285 costs $319 (3250e+Win 7 upgrade).
post #230 of 5037
But that system cannot handle 720p streaming flash video like the Acer notebook can (or at least that is how I understand it). That said, I should have been comparing the Acer AS1401-2285 to this config:
$369 (6850e CPU + Windows 7 upgrade) - 1080p h.264 blu-ray rip / MKV playback, 720p streaming flash video, 5.1 AC3/DTS over HDMI
So the Zino is a bit cheaper, but also doesn't include a screen but does have an optical drive.
post #231 of 5037
I am now wondering how the 6850e CPU + 4330 GPU + Windows 7 upgrade version compares to renethx's Mini-ITX.
Similar in price but renethx's system is customized with HTPC specifically in mind. I can live without any DVD or Blu Ray Drives as my main system is used to rip to my library. Just a bit more expensive as I will have to purchase W7, but maybe better in the ling run.
Intel/NVIDIA
System
CPU: Pentium Dual-Core E5300 2.60GHz 2MB L2 LGA775, $64.
CPU Cooler: SilverStone NT07-775, $20.
Motherboard: ZOTAC GeForce 9300-ITX WiFi GF9300-D-E LGA775 GeForce 9300 mGPU Mini-ITX, $140.
Memory: A-DATA ADQVE1A16K DDR2-800 2 x 1GB Kit, $32.
Graphics Card: GeForce 9300 (integrated in the chipset), $0.
HDD: Western Digital WD6400AAKS 640GB SATA 3.0Gbps, $70.
PSU: ATX12V 250W SFX PSU (included in the case): $0.
Case: Apex MI-008 Mini-ITX, $40. An alternative is Apex MI-100BK Mini-ITX, $48.
Total Cost: $366
post #232 of 5037
Yes. I tested it yesterday.
3250e or 6850e does not matter for the audio. It is the 780 chipset that enables 5.1 over HDMI.
Test set up.
Zino HD with 780 chipset (non MXM graphics version) connected to Yamaha 661 AVR via HDMI.
I was able to decode 5.1 DD/DTS content (DVD) on the Zino HD and pass the decoded content to the AVR and hear all channels out of each speaker. I forgot to check the bit rate and sample freq. of the content that was passed, but it was working.
I was also able to pass the undecoded DD/DTS content directly to the AVR and let the AVR do the decode. Likewise, all the channels were working correctly.
I think the content sounded slightly better when I let the AVR do the decode.
post #233 of 5037
Intel/NVIDIA
System
Total Cost: $366
The E5300 will obviously spank the neo X2. Not exactly a fair comparison.
post #234 of 5037
Well, the comparison is that they are both small form factor and similar price range. I find it dificult rank microprocessors, especially when one is intel and the other is AMD, so I thank you for pointing that out.
I think the NVDIA seems to have less documented issues and the GeForce9300 may also play better than the Radion 4330.
post #235 of 5037
renethx's build doesn't include the OS yet and it's not as small as the Zino HD. If you try to find a smaller case, cost tends to go up very quickly, not to mention it's darned near impossible to find a quiet heatsink and fan that will fit such a small case.
post #236 of 5037
The 9300 is on par performance with our RS780 chipset.
The 4330 will outperform the 9300 is most benchmarks.
post #237 of 5037
When will be possible to buy the Zino HD in canada? dell.ca doesn't list them.
Or is there anything similar to the Zino in canada? I'm noob in the HTPC genre.
post #238 of 5037
I am told very soon. Stay tuned to their site, you will see it available soon enough.
post #239 of 5037
The 9300 is on par performance wise as our RS780 chipset.
Thanks again for the info. Now leaning towards Zino again.
post #240 of 5037
This I'm taking with a grain of salt. I used to have a Radeon HD3450 and the ION does much better with 1080i MPEG-2 broadcasts. I believe the HD3200 in the RS780 is a step below the HD3450 so I'm going to have to assume that it won't be any better at handling interlaced content. I've since replaced the HD3450 with an HD4550 and that one handles 1080i MPEG-2 beautifully.
