i posted about a problem my zino 400 had back in september where it would blue screen when it was idle and one time came up with a hard drive not found error. i finally called dell and got them to come out and fix this. when i talked to dell support they said they would send a new hard drive, memory and motherboard to the tech. when the tech got to my house he opened the box from dell and claimed he only had the motherboard and hard drive. i explained to him the problem and he replaced the hard drive thinking that the motherboard was not an issue. sure enough once he left and i started using the computer i now get a blue screen when i'm in the middle of doing stuff rather than a blue screen when i leave the computer on overnight or for an extended amount of time. kinda annoying that he didn't just put everything in to begin with because now he has to come back out and fix this again. i'm hoping that with some new memory and a motherboard that whatever issue i'm having will be fixed. thankfully its covered under warranty and i don't use this computer a whole lot otherwise i would probably be looking to sell it once it gets fixed.
post #4951 of 5037
1/17/11 at 7:27am
maybe you should try booting it off an external drive, that way the heat won't affect the drive
