Originally Posted by DECJ
Very interesting indeed.
Just curious, but when you first discovered the maximum volume function, was it off or was it on? ... the latter state I assume meaning that it is attenuating the output power of the amplifiers(?) In any regard, it's an interesting conjecture, but unless the 807 unit HTM got their hands on for their bench testing already had the maximum volume function activated by someone else (which I agree they probably wouldn't have detected), then it likely would have still been in its off or unattenuated state. Beyond that, we'll probably never know one way or the other (although it seems from the HTM testing results, that the 5 channels driven results were OK, and it's only when they drove all 7 channels that the power/channel dropped-off precipitously, and I assume having the maximum volume function inadvertently activated would have knocked-down all of the results across the board).
But betting "10 organic cheeseburgers"? ... geeze, that's no fun, and I'm not taking that bet. Now if it was 10 big beefy & juicy coronary-inducing cheeseburgers, well then, I might bite.
hi ... when I found the Max Volume setting on my 807, it was not activated. It is interesting to note that this setting when active can be turned up ... or down ... I have not messed with it at all so far ...
yeah .... when it comes to cheesburgers .... well ..... the bigger, the better, truth be told!
