Originally Posted by
mikebtp
I've got the same clicking issue with the 807 even with a setup of a 7.1 system except that my last pair of speakers is set to Front-High. How are your speakers configured?
Mike
Mike,
If you are still experiencing the clicking with 7 speakers after you have done Audyssey Setup then I would thing you did NOT set the Input sources to Audyssey DSX and PL II Movie Audyssey DSX respectively, Right now I have no access to the receiver to try something else, but no other settings were click free for me. Or better say, this was the first combination I was OK with sound and it was " quiet" so it's a keeper.
My steps after I have wired the Front High (My layout doesn't allow for Front Wide:
Reset the AVR,
(I didn't needed the firmware update as the previous update wasn't erased.)
Run Audyssey
for the Input Sources of CBL/SAT
Select Audyssey DSX where applicable
Select PL II Movie Audyssey DSX everywhere else.
That is all I needed.
As for the Front High I have experienced the effect of sound "descending" with the aircraft only once or twice. So I am not sold on the effect of the FH but hey, it's not clicking so I am all good.
I should also mention that I am not an expert, just the user.
Hope it helps.
