AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo TX-NR807 Official Thread
Onkyo TX-NR807 Official Thread - Page 118
post #3511 of 5391
Originally Posted by marlon1925 View Post
Hey guys I bought a samsung ht-z310 and connected it to my Onk. I have read on the manual that when you turn the HDMI audio to "ON" in the settings it will automatically down-mix the audio output to 2 channel.
Is there a way to turn the automatic down-mixing to 2 channel so I can enjoy the full 5.1 audio of my DVD movies to my 7.1 set up? [nothing can be found on the manual to solve my problem]
I know I shouldn't be posting this here, but I have tried it posting in another thread but unfortunately I did not get answer for quite a while already. I am just wondering if anybody here has the same problem with me.
I really need your help guys
anyone please?
post #3512 of 5391
anyone please?
I for one don't have a clue what you're referring to. Do you own an 807 or 180?
post #3513 of 5391
G'day guys
I've had my nr807 for about 10 days and everything was working fine until last night.
The HDMI output seems to have stopped working suddenly. ie It was fine two days ago and then when i turned it on yesterday i couldn't get an output to my tv (Full HD 1080p compatible).
I have 3 HDMI cables going in (PS3, Sony DVD player & XBOX360). Sound from any of these inputs still work and I can display the 807 setup menus by changing the monitor output to analog.
I have replaced the HDMI cable b/w the receiver and tv and plugged in the ps3 directly to the tv to confirm it's hdmi input is working.
I have also tried re-setting to factory defaults all to no avail.
Is this a known issue?
does anybody have any suggestion about what i can try or setting i can check/change to maybe fix this before I bite the bullet and pull out my warranty card?
thanks - Jarrod
post #3514 of 5391
anyone please?
Hi marlon1925, this a setting on the HT DVD System which suppose to connect to a Tv or monitor and not a receiver. There is no setting on the ht-z310 to turn this to DD 5.1 unless the HT DVD System has a "Digital Audio Out" jack (which it doesn't). Best you can do is set NR807 listening mode to PLII/PLIIx.
IMO, return it and purchase some speakers (or speaker package) and a separate DVD unit or Blu-ray player.
post #3515 of 5391
Originally Posted by jmasas View Post
G'day guys
thanks - Jarrod
You should take it back, the HDMI board is broken.
post #3516 of 5391
JChin is right, that samsung ht-z310 already is a receiver and is not equipped to send audio to another receiver except 2 ch audio for tv speakers. You'll hafta us PLIIx or get a decent blu player.
post #3517 of 5391
Originally Posted by colour View Post
Mine was fixed after the update.
first thing i did when i got it was update to the latest firmware so that not it...
post #3518 of 5391
Then do this...... Setup->Listening Mode Preset-> (select the source where having the problem, usually DVD/BD or CBL/SAT-> D.F.2ch-> select All Channel Stereo, Dolby PLII or any other listening mode that keeps 5 channels active with 2 channel input = no more clicking.
As posted earlier, here's the "clicking" thread:
http://www.avsforum.com/avs-vb/showt...light=clicking
post #3519 of 5391
Originally Posted by kmike View Post
I checked mine too. I have some of those Monoprice HDMI cables with the big-assed torroids on them. They will take a 90 degree bend, making the torroid run parallel to the receiver and easilly fit the torroid body inside a 2 inch boundary beyond the binding post.
As you say, "where there's a will" and the key to making the 807 fit into a 19 inch depth will be using velcro cable straps to keep the stiff cables held parallel to the receiver where you want them without straining the connectors. Some of the low-profile HDMI cables might help too.
same problem here. i bought the 90 degreee benders from mono after the fact. much better.
post #3520 of 5391
no, if you read my original post, the clicking happens in the middle of a blu-ray, in this case Matrix Reloaded dolby true HD the audio format isnt changing, it just randomly make a single click (just like the click when changing formats) it did this about 6 times during the movie, more so at the end, so my theory is it may be a heat issue.
Also, when i was playing PS3 earlier today, the unit went to standby by its self. i turned it right back on and it came up find and didnt turn off again, its very warm to the touch, about the same as the other Onkyo units ive had. I'm going to try and hook up a fan for to see if that helps.
post #3521 of 5391
I know these units get hot but if it is actually shutting down because of heat you either have a defective unit (get it fixed or replaced) or your unit is in a location without 'reasonable' air circulation(?).
post #3522 of 5391
Squeeks...sorry, I'm late to the party..... only saw the post above about "blew up" and now clicking but what you describe sounds somewhat like the heat related HDMI popping the early 606's had. IIRC people could sometimes "fix" the problem with cooling, as you propose, but also sounds like the protection circuit is trying to do it's job. Might there be any load issues on the circuit(s) for the HT gear?
Just curious, what speakers are you running? Two units in a row with problems is maybe more than coincidence.
post #3523 of 5391
using all JBL northridge series same speakers that my old 805 powered for 2 years
its plugged into a monster cable power center that shows 120v on the line so that shouldnt be a problem
ive had terrible luck with these 180 referb units, bricked the first from firmware update, fried the second, now this one is having issues...might needa try something different.
post #3524 of 5391
Get out the fans!
post #3525 of 5391
So how's the ventilation?
post #3526 of 5391
Heh, I just (belatedly) set up the Pandora function on mine. Pretty cool.
post #3527 of 5391
Originally Posted by Leroy_Haynes View Post
I just got my RC 180 and finally got everything set up and got a chance to try out the streaming capabilities. Everything was smooth and painless, Pandora, Vnet, home server all set up seamelessly, but I have a question regarding the operation. I'm able to stream as I said, but once I have a tune playing, if I turn off my TV (either via remote or the TV) it turns off the receiver. Is there a way to turn off the TV once I've navigated to my playlist, song, etc. and keep the receiver playing?
tx,
Yes....provided you went through the the steps to enter the remote control codes that control the TV and other devices. If so, them simply press the yellow On/Off button in the TV section of the remote control (the one opposite the volume button) and the TV will power off but leave everything else operational....very useful, especially if you have a plasma panel. To get the display back again, just press the same button. HTH
Im having the same problem. Using the remote in the way mentioned above, it still turns everything off. Any other solutions?
post #3528 of 5391
Its in an entertainment center that is completly open front and back, and has about an inch to an inch and a half clearence from the top of the unit to the top shelf.
The previous 180 I had for 3 weeks did not have any over heating issues, so I dont know if maybe this unit runs hotter than that one did for some reason.
post #3529 of 5391
You sure? My 807 gets hot on one side of the top something fierce. And I have it out in the open. One inch of clearance and I'd be looking to put exhaust fans in that puppy.
post #3530 of 5391
I'm sure my unit does get hot, but the previous one never got to the point where it did anything strange from being too hot i.e. powering off or whatnot...
I do know the spot you are talking about, its right above where the power plug plugs into the unit.
I talked with the guy at the retailer i bought it from, he said i could swap it out again if i wasent happy. Maybe go to a marantz unit or a new 807. Not sure what direction to take, I'd like to stick with the onkyo simply becuase of the HDMI ports available.
Now that i remember the situation more. The unit did put its self in standby when i was using my PS3, and after i turned it back on I cant remember if i ever heard the clicking noise again. So maybe it fixed itself?
post #3531 of 5391
+1 I really like Pandora and use it a lot...maybe 3-5 hours a day. The cable box is also parallel connected with component and analog so I can just change the TV input source from HMDI to component and "audit" the TV while Pandora still plays away ...can switch back and forth easily.
post #3532 of 5391
Huh. Mine gets hot on the other side for some reason.
post #3533 of 5391
Not enough ventilation space IMO, get out a floor fan or something and blow it on high right at the thing for an entire movie that you've had problems with for a test. This, although not ideal for a long term solution, will reveal how your avr will perform under plenty of ventilation. If it performs well you should buy a cooler fan for it, if it gives you the same problems then ventilation is not your issue and you should consider replacing or buying new.
post #3534 of 5391
tx,
OK....got curious about this and here's the problem....you have RIHD hardware control turned on. To fix the problem, change this: Setup->Hardware Setup->HDMI-> OFF and the yellow TV On/Off button will now work independently the receiver.
BTW, this is the same control that can really mess up a firmware update.... MUST be set to OFF before an update or can brick the unit.
post #3535 of 5391
When I bought my Onk 180 I had never heard of Pandora. What a pleasant surprise to find I could customize my own radio stations. The quality is very good. And it is all free.
post #3536 of 5391
+1 on Pandora sound quality. I has listened through my iTouch a lot and also had a Denon iPod dock for my 988 but that connection was analog and a bit noisy. I was very surprised at how much better the streaming SQ was....and setting music optimizer = On helps too.
People gripe about having to listen to what Pandora want you too hear but I appreciate being exposed to artists that I never would have selected without my voting choices setting up the Genome preferences that pulled in similar music and vocals.
post #3537 of 5391
Whats up guys. New nr807 owner here. Just a little timid about updating the firmware in this thing. Am I naive in thinking I can simply use the latest firmware or doesn't logic apply here? Thanks.
post #3538 of 5391
Yes, you can just jump to the latest firmware.
post #3539 of 5391
Welcome!
And don't be timid on the firmware update. Logic does apply but it's the logic of the product and software engineers at Onkyo. If you were to read this whole thread through you would find that after the last firamware update people stopped complaining about connection dropout, clicking and a host of other things. The latest includes all fixes.
Read this first, then follow exactly and you'll be good to go:
http://63.148.251.135/redirect_servi...80_6_15_10.pdf
post #3540 of 5391
squeeks, I would be real suspicious about your hot spot on the left rear....that's power supply teritory. The usual hot spot is on the right rear above the amp section and is especially warm if using the video processor.
I know you said the power conditioner read 120V but you didn't mention current. Your receiver might be current starved. Can you try running it from another circuit, not just another outlet, and not on the power center?
