AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer SC-25 and SC-27 Receiver Thread
Pioneer SC-25 and SC-27 Receiver Thread - Page 170
post #5071 of 5085
Hi RickD,
Yes i have a sub...When setting all speakers to small the bass is OK and the high/mid/bass balance is not so bad...
Since RS8 are rated 33hz i was expecting to be able to set them as large and get good bass without a sub (especially when i'm in stereo mode and listening music....)
My computer speakers are Behringer TRUTH B1031A and i get more bass from 350$ speakers than 3500$ kit...(both using flat eq)
SC-25 is not listed as a 6 and 8 ohms capable... Maybe the PSU is running out of power when going down to these frequencies...
One thing that is strange with the SC-25 is that it's a 140watts * 7 channels AMP and the maximum power consumption is rated at 330watts...
OK Class D amps are more efficient than class A and A/B amps but not that much...
It seems pretty low to me...
Will try to play with again with XOver and Large setting to see what i can get... Normaly i use my cd player in pure direct...maybe switching to another mode that allow the loudness will help...
But again, since both AMP and Speakers are THX normally the default setting should reproduce the entire range properly at equal levels...
One thing is sure, i have listened to RS8 with very high end amps and when i get back to home i have the impression i have bookshelf speakers...
post #5072 of 5085
by my math, the difference between 40-50% efficient & 85-90% efficient comes to about 70% more!...I wouldn't call that "not that much" rolleyes.gif
330 watts of Class D power supply is about the equivalent of a 600+ watt power supply in a class A/B amp... close to or about the same as Pioneer's class A/B amp'd flagship receivers, from the VSX-49txi to the VSX-94txh models. the only receivers that could outperform these in real world power, all channels driven were the Denon 5805 & Pioneer SC-09TX, both of which were about $7000, had 10 channels...the SC-09 had a 1400 watt power supply for its 10 Class D Ice amps. Ice amps use a switching power supply, where the power is pulsed on & off according to the waveform at a very high frequency, so doesn't need the huge transformers & capacitors that a class A/B amp needs.
you might want to learn more about these amps. also read reviews with test measurements...that would clear up some of your lack of understanding - here's one for the SC-25's bigger brother from Home Theater Magazine:
http://www.hometheater.com/content/pioneer-elite-sc-27-av-receiver-ht-labs-measures
and FYI - the Ice amps in your SC-25 may not have been rated by Pioneer for 4 ohms, but were considered 4 ohm capable by the actual mfg, the Icepower division of B&O. they even have published performance data @ 4 ohms.
again, read the facts before coming to conclusions. they've been reviewed, tested by review publications with 4 ohm speakers and many owners of the Ice amp'd receivers use them with 4 ohm speakers, including me smile.gif also, other companies using Ice amp modules spec them for 4 ohm use.
bass response is highly room dimension, listening position & speaker position dependent. where you sit & measure the bass response radically effects the response at any given freq. you just may be sitting in a bass null at the freq you are noticing is lacking...try moving your seat or the mic when you do MCACC calibration. this is a topic for more discussion than I have time for now...but you are incorrect in your conclusion about the power supply. we can discuss your bass when I get more time.
Edited by ss9001 - 4/1/13 at 9:59am
post #5073 of 5085
if I can ask, did you own the amps or just listen to a setup in a demo room? if I already owned them, I would have kept them & used the receiver as a prepro but that's me smile.gif if at a dealer, comparing one room to your home acoustically is about as useful as comparing apples & oranges! bass response & acoustics in 1 room has nothing on earth to do with it in another room.
response at all bass freq's is highly dependent on the room dimensions and where you sit, relative to peaks & dips in the room at any given freq. which are due to wave reinforcement & wave cancellations. if what you said is really the basis of your comparison, I hate to break the news to you but you should spend time learning about acoustics & how room dimensions effect bass response. because you are making a totally erroneous assumption that the 2 setups are equal and the only difference is the amps! I can point you to websites like realtraps.com, gikacoustics.com and you can read about nulls, room modes, etc.
bass wavelengths are very long vs. high freq's. in any given dimension, the waves will bounce off the walls, ceiling & floor & add to each other or subtract from each other at very precise distances from ea room surface. because the waves are long, the effect of these cancellations & additions is very audible! and only a little bit of moving your listening position can make a big difference.
if your seat is in the place where there are multiple nulls, then you will perceive weak bass regardless of how much power your amp supplies! if there's a true dip or null, you could feed 1000 watts to the speakers & it wouldn't make a dam bit of difference to the volume at that freq. it's the laws of physics wink.gif
the answer in that case, is move your speakers or your seat a bit to get more or less bass output @ the freq you perceive is missing...better yet is if you use measurements & test tones. no room EQ system can compensate for nulls - you move the sub, move yourself, or move your speakers. if you want to test this, just play a song with a strong bass line, and walk around your room.
OK - now to details. are you saying weak bass in Pure Direct or with MCACC calibration on?
the calibration can make a big difference. plus how you do the calibration makes a big difference. the calibration will actually boost or cut your preamp channel levels to reach the designed input levels to the amps, plus increase or decrease 9 freq bands, starting at 63 hz, to match a target curve. did you look at the EQ data to see what it did? did MCACC cut the front 63, 125, or 250 bands? you can manually increase them to taste (read the manual)
how you position and use the mic makes a big difference.
1. where did you place it? it should be at your listening position, placed on a boom or tripod so that it's close to where your ears would be
2. mic should be pointed directly up to the ceiling, parallel to the floor, horizontally level, not tilted in any way forwards or backwards
3. mic should have a clear line of sight to ALL the speakers, so that seat backs, etc do not obstruct or in the line of sight between the mic & speakers
4. are you in the room, near the mic, when measuring? if so, get out of the room or at least not next to the mic
the MCACC EQ does not do anything to freq's < 63 hz. but of course, any EQ'r has a Q band where a cut will also effect lower & higher freq's. you can also try turning the Standing Wave filter or Phase Control off to see if there's any difference, although usually those will help improve your bass response. they are on by default.
where is your crossover to the sub? THX recommends setting speakers to Small & using 80 hz, even with so-called full range speakers. you say you have good bass with the sub but not without...is that in Pure Direct? if so, your receiver isn't doing anything to the freq EQ. what you get is what you get off. it's possible that your room is so large that your speakers "might" perform better with larger amps but you haven't enough to come to that conclusion, IMO. you could use the Plus sub setting with fronts set to Large, so that both the sub & fronts get full bass, but that is not usually the best recommendation.
your Monitors aren't particularly demanding, being 6 ohm rated, 40-175 watt suggested power & 91 dB efficient. certainly easier to drive than my 85 dB efficient Magnepan speakers wink.gif compared to yours, my Maggies would take over 3 X as much power to achieve the same volume as yours! ( 91 - 85 dB = 6 dB). so I have a very hard time believing the Pioneer doesn't have enough power.
did you move the speakers or your seat in the current setup? you may have just moved them into a null (bass suckout) position. did you stand up & listen several ft in front of your chair & behind it? if so, did you notice changes in the bass? did you play a test tone disc to hear which freq's are louder & which are softer?
you can see, you have many things that could be contributing to your bass response, the least of which is the receiver's power rating wink.gif if you like to listen to near reference levels (0 dB on the dial) and the receiver is running out of gas, then I would think you also would know it by harshness, raspiness indicating increased distortion or getting close to clipping & compressed dynamics, not a general perceived lack of bass at normal volumes which is freq response. Planars like Magnepans do come alive with lots more power, but your Monitors are pretty conventional speakers in design & construction and pretty efficient, too.
hope this helps your understanding. if you want to discuss further, or provide more details on your room, some of us may be able to help with some suggestions .
but if you choose to believe another amp is all you need to solve your problem...then that's your choice.
Edited by ss9001 - 4/1/13 at 12:32pm
post #5074 of 5085
I'm considering buying a dedicated amp with more power reserve for the fronts... Like emotiva xpa-2
while that could help you on headroom, real world volume difference is not so impressive, plus it won't necessarily perceived bass freq response due to room acoustics:
here's the math -
dB volume difference = 10 x LOG(power1 / power2)
using rated power @ 8 ohms of XPA-2 and SC-25 for comparison,
dB volume difference = 10 X LOG(300/140) = 3.3 dB
at maximum peak output, you will get only ~3 dB more volume with an XPA-2 over the SC-25. that's all & that's hitting a max peak of 300 watts! and that's the same as turning the vol up 3 dB on the dial wink.gif
to show what 3.3 dB really means, a difference of ~1 dB is the min perceptible change in volume, 3 db is a moderate change in volume, and 10 db is approx perceived doubling of volume. at normal listening levels, you will not hear any significant difference between the 2 amps, if any at all! only when you turn it up to very high levels & only then when you hit a 300 watt peak would the bigger amp come into play. that's the reality of doubling the power, it makes only a little bit of audible difference in volume. it takes 10 X the power to double the volume! and that still doesn't address what you perceive as weak bass!
and fwiw, emotiva shows the XPA-2 has "unavailable" now. whether this means temporarily out of stock or them gradually phasing out to the XPR models, you'd have to call. I have nothing against Emotiva amps, have considered them myself if I ever went to separates. but I am presenting the math behind the hype so you have more info on making an informed decision.
if having more power is your thing, then that's understandable, but don't think doubling the power is going to really fix issues with bass response due to room acoustics. you'll need to spend time with positioning, possibly bass traps, and your calibration to do that.
Edited by ss9001 - 4/1/13 at 12:16pm
post #5075 of 5085
+1.
The largest difference between the dealer and your room is the room... Also, dealers tend to tweak for impressive, not necessarily accurate, sound.
post #5076 of 5085
I just picked up a SC-25 off an auction for a steal. The seller stated that hdmi audio wasn't working, but otherwise it seemed to work ok.
Personally I don't care if hdmi audio works or not, as long as I can switch things over. To be honest tho, it sounds like it was probably a device configuration or hdmi handshake error.
So, I'm hoping that I don't have to send the thing off for service. Any thoughts on the audio issue?
Second, It's got no remote. I'm hoping that I can use a harmony I have laying around to get things configured. Any thoughts on that or should I pony up $50 for a replacement remote?
I'm pretty stoked to pick up a decent receiver. My onkyo dropped into failsafe mode and I don't feel that it's worth having serviced. Meanwhile, my second hand rca branded pioneer is still going strong in my office, so I like the idea of heading back to pioneer land.
If I do need to get service, any suggestions on the process? I think I have a local elite dealer I can work through...
post #5077 of 5085
I'm always amused when I talk to myself. Update on my recent SC-25:
1) It appears to work perfectly. I had no issues with audio over HDMI at all.
2) I tried using the setup microphone from my onkyo with the SC-25. It appears to have worked just fine. There could be some eq curve that it's quite right, but after running through setup I was impressed by the results. It was able to identify out of phase wiring on some of the speakers and appeared to tune things nicely.
3) The input select is a little soft on the response side. I'm used to a selector providing a click feel and actually changing. Mine is a bit laggy. I improved response by turning off un-used inputs.
4) I tried using a harmony remote, but have failed so far. I need to look up the remote-setup button on the harmony config so I can kick off the remote setup macro.
5) I had my bluray connected to the BD hdmi but also the component to a selectable video input. Some commands would send an init down the hdmi cable, making the receiver select BD even though I was using a different video input. (my TV is component only, but my projecter is hdml.) I've opted to go component so that video is scaled for the projector (which is only 720p) and still looks fantastic.
Final thoughts - even with my inexpensive onkyo speakers, the audio is a huge improvement! I'm impressed by the audio performance and glad I got the pioneer.
post #5078 of 5085
Hi Will,
Being a slightly older Pioneer model now there isn't as much traffic in this thread as there use to be. Really glad you're liking the SC-25 though. I've been super happy with mine for quite a while now. I also came from an Onkyo and could really tell the difference. The D-class amp does a wonderful job powering my 7.1 Paradigm Studio series speakers. For my listening levels the 140 WPC/ACD is plenty, I hardly ever go louder than -15 and that's only for movies. I'll probably keep using it until It blows up or I die biggrin.gif
Never been a fan of the Harmony remotes. A friend of mine bought a new one and let me try out his old one that was only a year old. Too much trouble to set up and then it breaks (the LCD screen stopped working on it) and you get to buy a new one and do it all over again. My cable box and BD player remotes get the most use, the cable box remote is programmable for several components so I mostly use it.
If you haven't read this whole thread there is a lot of info you might find helpful, it's only 170 pages wink.gif That's nothing compared to the Paradigm speaker thread.
Speaking of speakers, get yourself some bad boys and crank it up!
post #5079 of 5085
Lots of info in this thread. 1st thing I dont need the video upscaling to 1080p for my displays so I can watch TV in 1080p instead of 720p like I have with my vsx-33 in my downstairs setup. Nor am I using heights or front wides. for my upstairs livingroom.
This setup is for my upstairs livingroom. I will be using a bdp-23 and all my speakers are Energy Veritas. V2.3i for front towers, V20Ci center and V2.2i for surrounds. Question is I have a VSX-03txh but want to give the SC-07 or the SC-25 a try in this setup. If I go with the SC-25 the total cost would be 111.00 more than the SC-07. These of coarse are both used and cosmetically look really good. Is the SC-25 a better receiver and worth the extra 111.00? Also will either of these be better than my VSX-03txh I have now. I spend an even amount of time between music, tv and movies with this system.
Thanks for the help.
post #5080 of 5085
Hey Baron, I have the SC 25 and love it!!!! Originally I had the vsx-01 and it was clearly night and day with the sound. The ICE amps are well worth it. I really dont know anything about the SC-07. I have Energy RC 50's,
RC LCR and RC 10's and love it.
post #5081 of 5085
Hey tang, thanks for the fast responce in a dying old thread.
post #5082 of 5085
tang I have an RC setup in another room as well. Nice speakers.
Edited by baron2 - 5/4/13 at 2:45pm
post #5083 of 5085
I had the SC-07 for a year and got an opportunity to switch to the SC-27 after that.
The main differences between the SC-05/SC-25 and the SC-07/SC-27 is that the #7 have a bit more power, additional inputs and a different THX certification. You should go on the pioneer website to browse at the specifications in the archives for the details.
The main differences between the SC-05/SC-07 and the SC-25/SC-27 is that the 2# have a few more bells and whistles. One thing I do like about my 27 is the ability to set a default volume level when powered on. I did some posts in the past about other differences, you might want to search on my posts to see if you find it. If you don't, let me know and I'll try to dig it up.
Dan
post #5084 of 5085
Dan
Thanks Dan for the info. I went to pioneer usa to see some of the differences. On the SC-07 it has TXH loudness plus but when looking at either the SC-25 or 27
I cant find TXH loudness plus in the specs. Did they rename this feature for the 25/27? I thought I saw something in a thread somewhere saying its called something different
for the 25/27 but dont remember where I saw that. Been searching threads but cant find it again.
post #5085 of 5085
^^^ As discussed by PM, 25/27 also has THX Loudness Plus, as documented in the manual.
Dan.
