Originally Posted by CHP_VR
William06;
Only thing I can think of is this happened when I first set up my DV-59AVi...
Resetting it brought everything the way it was supposed to.
To reset it.
From your 49 manual (page 70):
Resetting the player
Use this procedure to reset all the player's
settings to the factory default.
1 Switch the player into standby.
2 Using the front panel buttons, hold
down the 7 (stop) button and press
STANDBY/ON to switch the player back
on.All the player's settings are now reset, and
you should see the Let's Get Started' screen.
Other than that, double check you have it plugged in to component 2..
then double check that it's setup to operate in component 2 in the input setup menu as VIDEO2..
(component2 default is DVR - see page 32 of your SC-27 manual)
William06;
To reset it.
Hey thanks I will give it a try and let you know. I really want the 45 for just the sacd and dvd a and hate to buy another unit I really did not want the oppo and like the 23 so far.
