Originally Posted by bossobass
I mentioned the physical speakers as being random phase (because they are) because JPC is confusing the discussion by asserting that the bass manager summing block sums with the "Same gain as co-located subwoofer bass summation", which is nonsense.
If you add and co-locate a sub of equal displacement and input power, you would then recalibrate the system, and since no multichannel system co-locates the 5 sats, they are random phase.
Example:
A system has 5 sats and a sub, all of which are capable of the 3-120Hz (+/- 0.5dB) specification. It is perfectly calibrated and has a perfectly flat in-room response at the LP.
Set the system to Dolby Configuration 0, all sats to LARGE and sub to YES.
Play the effect that is equally encoded onto all 6 channels at 0dBFS and capture the peak in dBSPL with a meter.
Now, switch the system to Dolby configuration 1, all sats to SMALL and sub to YES with an 80Hz X-over.
Play the same effect.
Does anyone believe the meter will read 6dB higher because the AVRs bass manager is summing the 5 stats LF with the LFE with the "Same gain as co-located subwoofer bass summation"?
Does anyone believe the meter should read higher at all?
Bosso
Example:
Bosso
Where did you dig up the 3 dB gain figure for signal addition?
The 120 dB SPL PEAK number is based on 3 channels of bass added to the LFE bass. 5 channels of bass will give you higher levels.
Pan_Law
"Pan Law (aka pan rule) is a recording and mixing principle that states that any signal of equal amplitude and phase that is played in both channels of a stereo system will increase in loudness by (up to) 6.02 dBSPL, provided there is perfect response in the loudspeaker system and perfect acoustics in the room."
Single (blue) and 2 channel (purple) signals electronic. 6 dB of gain for 2 identical signals being mixed together electronic.
Same acoustic results with my stereo speakers, 6 dB of gain.
Same acoustic results with my stacked subwoofers, 6 dB of gain.
Same results with my crossover unit, 6 dB of gain electronic.
Same results using a Y connector on my subwoofer input (R & L), 6 dB of gain.
