An earlier perusal of specs suggested not much difference between the ES changer and the one to be released. A closer look reveals some differences. Only a side-by-side will indicate whether the differences matter.
What ES Has That Non-ES Doesn't
1. Deep Color
2. HD Reality Enhancer
3. Super-Bit Mapping
4. 3 IR Code Sets Built In
5. Individual Speaker Setting -Speaker/No Speaker
6. 7.1 Channel Analog Outputs
7. Composite Video Outputs
8. S-Video Outputs
9. RS-232 Control
There may be more, but this is what I could glean from a closer look. The ES version is also nearly two pounds heavier, perhaps owing to some sturdier parts.
I'm still betting that the two will be substantially the same, but if any of these features truly translate into a difference, then perhaps the ES will provide performance enhancement.
Nick
1. Deep Color
8. S-Video Outputs
9. RS-232 Control
Nick
! I'm talking about the ability to integrate multiple changers without having to spend thousands on Escient!
