Originally Posted by
mintakaX
Would the Macmini option require an Apple TV ? Because I was told the Apple TV wont stream ISOs ?
It is computer, but you it depend on the Software in Mac OSX. It has hdmi, so it can be plugged into the TV. Also, mentions that it will be able plugged into a Thunderbolt Display.
You can use XBMC now, but I personally don't like XBMC.(XBMC is open source, but free) J River Media Center is developing it for audio by the end of the year. Eventually, you see video next. The easy way to get around an ISO is to take extract it folders.
mintakaX
I absolutely dread the thought of setting up an HTPC, Mac or PC. I work in scientific software development and couldn't stand the thought of doing computer stuff on my time off.
Rather easy now. I can put one together in less than an hour. Software takes time, but the SSD drives make it a breeze. Static electricity can be bad, so you spend $5 on wrist strap. Easy and saves you money. Here is a company that will put one together.
http://www.endpcnoise.com/cgi-bin/e/hfx_classic_fanless_pc.html
See if you have a Microcenter near you. It is large computer store. I leave the specs for people, but just go ask them to put one together. I think they charge $80 to $100 for labor. plus the cost of the parts. Most local computer stores still do this, but Microcenter allows you to pick out the parts.
mintakaX
I wonder if a WD Live TV device in combo with a NAS might work ?
Never heard of it, but seems limited.
mintakaX
I really like what the Vidabox does as it is pretty much one stop shopping for putting your discs to media. Its just too expensive, especially if you add any kind of redundancy (adds an extra $5K for RAID option for 480 Blu-rays).. thats almost $10K just to replace the functionality of my changer.
I guess I'll just hope my CX90 keeps working until something easier or cheaper comes along. /quote]
Well, the changer is the best option, but now they are rather expensive. There is people that will charge you lot for alternative solution.The problem with Bluray is that you need an HTPC that will expand, so that setup will do it for you.
