AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › has anyone used a CECB in their vehicle?
post #1 of 12
ok - I'm finally found my $40 coupons (lost them for about 6 weeks!)
now of course, almost all the 'good ones' are gone - but anyways...
has anyone used these converters in their vehicle to update their car TV to use these Converters? we acquired a TV in our Denali (we bought used) - and it doesn't pick up much of anything - wondering if the converter will help
thanks!
post #2 of 12
Did a search for camper.
http://www.avsforum.com/avs-vb/searc...rchid=13613992
post #3 of 12
Maybe - if you're doing a tailgate...
Oh - you want to watch while the car is moving ? - Forget about it - your best hope will be if any of your local stations are doing the ATSC M/H as part of what they transmit. Even then - you'll need a compatible tuner for your car.
Otherwise - You'll probably be reduced to using DVD's.
post #4 of 12
thanks!
Only when the vehicle is not moving would a converter box work.
There is different standard for Mobile Digital TV, which is in testing at this time. No date has been announced for when Mobile DTV products will be available.
See this topic for more details: http://www.avsforum.com/avs-vb/showthread.php?t=1029236
post #5 of 12
I've used my Insignia (Zenith-equivalent) box in the car using an AC converter numerous times.
As noted above, you can't do it while moving, of course...the signal just won't hold.
post #6 of 12
Wouldn't it have made more sense to come up with a digital TV method that'd work for both moving and stationary receivers? As it is now, a separate "Mobile DTV" system uses up more of the airwaves for a separate format.
post #7 of 12
Yes, it would have. But nothing we can do about that now.
post #8 of 12
less money to be made with one format
post #9 of 12
Not for the broadcasters.
post #10 of 12
Careful not to tread too heavily in this area folks, lest you summon some demon (with the initials "B.M.") who desires to refight 8-VSB vs COFDM. If you don't understand the reference, perhaps best to let it be...
post #11 of 12
Yes, please, let it be.
post #12 of 12
I've seen it work for a few minutes at a time, with strong signals, but it's highly variable and is not worth trying.
I've even gotten locks on airplanes before. However, ATSC simply wasn't designed to work while moving.
FloTV does ok, in moderate to strong signal areas, but I have yet to test MDTV yet. I'm not aware of any active broadcasts in the LA area.
