Hello,
While going through Comcast's by-phone activation procedure for their digital cable equipment last Friday, I asked the Comcast rep if I should/could connect their DCT2000 set-top box to the TV via the RF coax or the red/white/yellow composite video-audio connectors. She was emphatic that I should use the composite video and NOT the "antenna/cable in" port on the TV.
This made me even more curious. So I disconnected the composite cables and hooked up an RF cable from the set-top box into the TV. I'm getting a signal anyway. The difference seems to be that the TV recognizes the signal as coming through the "main" input, whereas with the composite video option I had to choose "external device" to see and hear the channel.
Is there a downside to using the RF route rather than the composite route? All else being equal, I'd prefer the RF route since it leaves the composite ports free for a VCR.
Thanks for your insights.
--JorgeA
--JorgeA
