Originally Posted by
Neurorad
So, you don't deny that you know Mr. McCook personally. Got it.
Some of your postings are comic relief. Thanks for the laugh.
I also did not deny knowing the president of the United States either.. nor, have I denied knowing you personally. How many people will I have to deny knowing? One billion? Two?
Everybody sees your statements here as diversionary. Look... you assumed either a personal or a business relationship existed, not a problem. Just accept the responsibility of the error, admit you made a mistake... No problem.
Neurorad
This is one of the quotes that threw me:
text:
""Originally Posted by westom
So go to Lowes or Home Depot. Ask for a less than $50 'whole house' protector. Then view spec numbers. It must be 50,000 amps or higher so that even lightning strikes cause no damage."" end of text..
Ok, easy enough to answer...the first half is a statement, the second is a horribly inaccurate assumption.
The ability of an MOV to survive depends on several factors.
1. It's physical volume: The energy it absorbs will increase it's temperature, based on the heat capacity of the device. Double the volume, roughly double the joule rating.(while not exact, for the purpose of discussion it will do.)
2. It's voltage/current rating. Voltage will be roughly related to it's thickness between terminals, and current will be roughly related to it's area: At high current ramp rates, the current capability will be related more closely to the circumference, as high speed currents will tend to skin within the device, crowding the edge and avoiding the middle.
3. The conduction path characteristics which carry the pulse. Unvaporized copper wire will have it's resistivity, so indirect strikes which do not vaporize the copper will be tempered by the path resistance. Once the copper has vaporized, the resulting plasma conduit is essentially a
really good conductor. Same with the ionized air channel.
If you exceed any of the MOV ratings, survival is not guaranteed. the 50 kA spec is a rating based on a 8uS/20uS test, not a lightning hit. A direct strike can run 150 kA in one direction, 300 kA in the other.. Needless to say, a 50kA device will NOT survive a direct hit like this.
What a 50 kA device WILL do, is protect the house in the event a strike occurs to the utility structure anywhere in the neighborhood. When that happens, the utility wires are delivering the transient to your house. The utility wires provide a real tempering of the violence of the strike. By the time it gets to your house, there are large wiring resistive and inductive drops.
The statement that a 50kA device will protect a house against a direct strike is an outright lie. And, a dangerous one. w-dude regularly lies about some florida tower failure..claiming that even when it met code for earthing, it's not enough...yet when one reads the article, it clearly states that the grounding resistance was 550 ohms. The article states rather nicely, that the earth bond failed code by a factor of 22.
Neurorad
I don't understand why you would respond like this
Because a direct strike will indeed destroy a whole house spd. In no way, shape, or form, should idiotic statements regarding safety be allowed to live.
Neurorad
- but I'm aware you've discussed these issues with westom in other threads, in multiple forums.
Now your really making things up.
There is no such thing as a
discussion with wes-dude. Given facts, he ignores them. Given technical questions, he never answers them. All he does is cut and paste and denigrate....but, our discussion is not about him. It is about surge supression and engineering facts.
So as I said, ask away, I'll be happy to answer.
Neurorad
Maybe you're just frustrated.
With what? Him? As I've stated, he is comic relief..and entertainment which allows actual engineers to post actual knowledge that others will read. Without him, this thread would be boring.
You? Nah. Your slant is also entertaining. It appears that your schtick is to use conspiracy theories to denigrate others by fabricating ulterior motives. Fun to read. but frustrating???pfffft. Perhaps if I were part of a conspiracy, I'd be frustrated..but let's face it...your posting has allowed me to provide technical content that would otherwise be rather boring..that is a good thing..
Neurorad
What rating would you suggest for a whole-house SPD, if not 50 kA or higher?
The big guys like eaton range from 30 to 60 kA devices for residential. Larger is always better.. Eaton (IIRC) has a great website with lots of clear content put into laymen terms, and they detail such things like using end of branch devices in cascade coordination with a whole house unit. If you need a link, I could google, or perhaps you could.
The biggest issue I see is the use of single port vs multiport end of branch spd's..there is lots of confusion out there on that, and wes-dude is one of the most confused in that regard..just look at his mis-quotes and mis-interpretation of Martzloff.
Cheers, John
oh, almost forgot...
No, I don't know Mr McCook personally, professioinally, nada....case you were wondering...
(I know if I do not deny it, you will continue the harrassment..
