AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Western Digital - WD TV Live Media Player (WDTV2)
Western Digital - WD TV Live Media Player (WDTV2) - Page 91
post #2701 of 7079
Originally Posted by vv132 View Post
Hey i'm looking to buy a wireless usb network adapter to attach to the wdtv live, which will be able to be seen by my mac book pro so i can transfer files wirlessly to the USb attached to the wdtvlive. Can any wireless G usb adapter work....i've seen the list which all have N capabilities, but will G work also? Trying to just get a cheap one, since i'm really not streaming anything. Can anyone suggest any known working ones....outside of the compatibility list?
thanks
V
I got the Linksys WUSB600N Dual-Band Wireless-N USB Network Adapter from buy.com for $30. Yes it is refurbished. No I have not had any issues with it. No I could not distinguish it from the brand new version of the same adapter I bought and returned.
I use it to let both my iMac and PC connect to the WDTV Live.
http://www.buy.com/prod/linksys-by-c...211086125.html
post #2702 of 7079
Originally Posted by mrkeeling View Post
Here is a bug that drives me crazy:
If you have a DVD rip with more than one title you are in for trouble.
If everything is in VIDEO_TS folder (as it has to be to play all the VOBs seamlessly and to have subtitle support - we learned), it will play the BIGGER title first and completely ignore title order. If your Title 2 is bigger (in bytes) than Title 1, it will start playing with Title 2.
On the other hand if the files are in the folder that is named differently (NOT VIDEO_TS), it will start properly (with Title 1), but you can kiss goodbye seamless VOB playback and subs support.
Wonder if there is a fix on the way for this?
Is B-Rad's firmware doing this properly?
Strangely here if I play a ripped DVD structure and it is NOT in a VIDEO_TS folder sometimes I get no sound. Also the VIDEO_TS folder needs to be capital letters also to play correctly!! So basically I'm either converting all my rips to MKV or creating the proper VIDEO_TS folder. Some movies I have don't have that folder or are in lower case.
post #2703 of 7079
Originally Posted by mrgimble View Post
Perhaps you should post you comment without context in the xtreamer thread.
Originally Posted by rick19011 View Post
Xtreamer looks a lot better in comparison to the dvd sample
Both of you guys blind? There is context cause a few posts up a screenshot comparison is posted which is also clearly in favor of the standalone. Since it's not my screenshots I cannot provide the same motive displayed by the WD TV.
Originally Posted by jherring69 View Post
Who cares about DVD
Apparently a lot of people considering requests in this and the original WD thread.
No surprise there as capital letters are required by the DVD specs. And what's stopping you from renaming them or making a folder? Of course you could just as easily use ISOs.
post #2704 of 7079
17 posts up is not a few.
post #2705 of 7079
Originally Posted by Lt. Dang View Post
What format are your videos - are they vobs for instance?
Lt. Dang
Lt. Dang, I have just had a quick look at 4 of them and they are avis with a mixture of xvid and div3 codecs.
Last night I tried using MPEG4Modifier to change the aspect ratio of a few videos, it was quick and seemed to work on the xvids but it couldn't do the div3 ones.
post #2706 of 7079
I'm slowly addressing this. Eventually I'll have full title set support for dvd's and later on pseudo-menu support. Its going slow because I am extremely busy and I'm doing it for fun+proof of concept, the feature doesn't really do much for me.
post #2707 of 7079
It happened to me too but I had also connected optical toslink to the receiver. I checked if receiver was getting the sound if not TV which was connected via HDMI. Yes, the receiever gets the sound. And it is 5.1 too.
post #2708 of 7079
I hought D-Link DIR-655 and Buffalo USB network adapter WLI-UC-GN US. Everything is working except after 15 or so mins, WD TV Live drops the signal. Only way to restore it is to reboot the WDTVlive. Has anybody experienced this and found a solution?
post #2709 of 7079
Well....I got mine last night and other than the minor issue with sometimes needing a soft power cycle to restore networking I ran into a much more serious issue with playing a video.
Twice, when jumping around with the 10min. skip feature, during DVD VIDEO_TS playback the video would just go black with no sound either. This is after hitting play after using the 10min. skip feature. If I hit stop the menu comes back up, but any video I select from that point on would not play; just a black screen. The only thing I could do was a hard power cycle and that would fix it.
Anyone see this issue?
edit: 100Mb wired
post #2710 of 7079
Originally Posted by video321 View Post
.... Anyone see this issue?
Yes.
post #2711 of 7079
I'm considering selling my WDTV for a Live. 2 questions - Is the Live smoother in terms of overall interface speed/performance? Is there good 3rd-party FW support for the Live, like the WDTV had?
post #2712 of 7079
Hate to be the bearer of bad news but it is not the WDTV Live dropping or disconnecting..... read the Forums.... I found some answers...
http://www.avsforum.com/avs-vb/showthread.php?t=1195085
post #2713 of 7079
New to this WDLive and the whole youtube thing really like the device. Anyone know how to make a youtube playlist loop or go on with out having to hit the button after every video to get continuous play? Thanks
post #2714 of 7079
Twice, when jumping around with the 10min. skip feature, during DVD VIDEO_TS playback the video would just go black with no sound either. This is after hitting play after using the 10min. skip feature. If I hit stop the menu comes back up, but any video I select from that point on would not play; just a black screen. The only thing I could do was a hard power cycle and that would fix it. Anyone see this issue?
Yes and in my case it happened during ISO playback from an attached USB disk.
post #2715 of 7079
Guys a question. How can we play external subtitles on a bluray iso? Is it possible?
post #2716 of 7079
edit: 100Mb wired
Please post this in the WDTVFORUM.COM forum as there are alread two people with the same problem. I am one of them. After that happens you have to almost reboot everything, including the player with a power cycle. Why? Have no idea, I just gave up on anykind of fast forward or rewind with this player. My Ultio 800 ripped right through it and NEVER backed down.
post #2717 of 7079
I have tried external .srt subtitles on BR .m2ts and it works perfectly well ... Just name the subtitle file the same as .m2ts.
post #2718 of 7079
Weird bug
This is an .mkv with an external .SRT subtitle. Notice how the subtitles are way too high, inside the picture frame.
Now this is the same movie and subtitle, merged as a new .mkv with internal subtitles. Notice how the subtitles are now better positioned. If there was a smaller space between the 2 subtitle rows, it would be even better.
To WD: if you cannot give a "subtitle position (offset)" feature, so we can position the subtitles as high as we want, at least make the external subs look like the internal ones (lower). They are too high. Thanks
post #2719 of 7079
I am trying to avoid the extra process of creating an ISO file. I created a movie folder , then in that folder I placed the jpg file and the Video _TS file. This did not work. What must I do ? Tks
post #2720 of 7079
Use a program that will rip directly to an iso. Then add the jpg to the same hdd.
post #2721 of 7079
Ok, got a few questions..
1) Overall, how well does this bad boy work with PlayON? I would love to be able to watch Hulu, Netflix, Revision3, TWiT, etc. using PlayON with the WD Live TV
2) 90% of the SD movies I have are in AVI (using xvid) - will these play flawlessly?
3) If I play an AVI/MKV that has 5.1 surround sound, will I need to do anything special to get true 5.1 surround sound through my receiver? As in, have the listening mode actually display "Dolby Digital EX" or whatever?
Main reason I'm wondering about #3 is that whenever I play movies that have 5.1 surround sound on my 360 using my portable HDD, they definitely are not in true surround sound. I'm using an optical audio cable and get true 5.1 surround when I watch normal DVDs and when I play 360 games.
Just want to get some feedback before I make the jump - thanks guys!
post #2722 of 7079
Playback via PlayOn works. The big problem I've seen is with fast forward and reverse. After FF or RW for a while playback stops and returns to the start.
The only thing I've found that doesn't work is Xvid's (3 warp point) GMC. DIV3, DX50, XVID, QPel, 2 B frames, packed bitstream, unpacked bitstream -- all work.
From what I've read this works as it should but I haven't used the digital audio output yet.
post #2723 of 7079
Originally Posted by freestyler677 View Post
Weird bug
Yes, I am having the same issue too. Hopefully WD will look into this soon.
post #2724 of 7079
What would be even better: make the sub's outline intransparent again as with the original WD TV, see attachments.
post #2725 of 7079
hummmmmmmm
post #2726 of 7079
Originally Posted by cosvid View Post
I am having the same problem. Did you ever get it resolved?
After the firmware update, the issue seems to have gone, although I have only tried 1 movie which was having issues previously. I am yet to check the other movies that had the same problem.
post #2727 of 7079
How about adding it as an option instead of the box choosing for us?
post #2728 of 7079
Originally Posted by keneso View Post
Can someone help me?
I would suggest that you try changing the way you have the WD TV Live connected to your audio device (TV or AV receiver?) to see if that makes a difference (perhaps use Toslink cable instead of HDMI?). That is all I can think of, but maybe someone else here can offer some other suggestions. Anyway, I hope you're able to get things working soon.
post #2729 of 7079
Hello all,
I'm about to get the WD Live and I'm looking at external HDDs. I've seen the WD My Passport Mac edition on sale a lot cheaper than the standard PC, just a question...can I just format one of those using my PC then use it as normal with my WD TV Live?
Thank you.
post #2730 of 7079
I'm very satisfied with my WD Live but I hope someone can help me with the network shares.
The network connection on the WDTV2 is ok and I have made some shares on my PC. On the WDTV2 is see the PC under Video/network shares. User and password is entered correctly but then I get a message "there are no files on this folder to play". Have the shares to be in a certain form? (the manual says nothing about that)
I didn't install any of the software (on the CD)
