Many thanks to salacious and ricabullah!!! Reaaaaally appreciate your help!!!
Under your inspiration, I went to check the Manual Setup for RX-V863, Under Audio Select -->HDMI Set --> RX-V863. (was "other", meaning pass the audio signal to other device.)
Now, I get my Intel HD Audio support Multi-channel.
Thank you so much.
But yet, I don't have bit-stream HD from TMT3 or PD10...they both set to use HDMI audio output. any thoughts or help are really appreciated.
keep researching...feel I am seeing the light
Thank you so much.
) in XBMC 9.11, no problems with audio sync too (using Digital output, DTS, DD passthrough) also enabled Vertical blank sync in XBMC.
