AVS › AVS Forum › Video Components › Home Theater Computers › Core i7, i5 & i3 LGA1156 Processors Thread: Clarkdale Supports HD Audio Bitstreaming!
Core i7, i5 & i3 LGA1156 Processors Thread: Clarkdale Supports HD Audio Bitstreaming! - Page 110
post #3271 of 3675
Originally Posted by Mopar_Mudder View Post
Tried that and still no BTB
Maybe it is in my head but it looks like their is less shadow detail, blacks all running together, then I had on my ATI 5700 card. I would have to hook it back up to tell for sure but it just doesn't look as good.
I just wanted to update that I ran the i3 and my old ATI 5700 side by side last night. Well not side by side but different inputs to the AVR so I could switch back and forth between them. Looked at a few different images from 2012 and to my and my wifes eye we could see very little difference. The 5700 might have just a very slight edge in shadow detail but in some shoots we could se no diffrence. So the blacks were not as bad as I thought with the i3 maybe it is that movie? Will have to get hooked back up to my Sammy 46B750 so I can try to compare to that. Wish I had a stand alone BluRay player to compare to but I don't.
post #3272 of 3675
Has anyone found a work-around for the reboot on receiver port switch problem? I loaded the latest drivers hoping that would resolve it, but it has not.
post #3273 of 3675
The latest Intel HD Graphics driver supports hardware acceleration of H.264/VC-1 on Windows XP.
Is this new or not? I thought the requirement of DXVA2 prevented Intel GPUs from doing that.
post #3274 of 3675
I have been doing some reading here about the ASRock MBs and the Intel Management Engine. I have a ASRock H55M rev 1.02 and I believe I have a successfully installed IME driver under w7 ultimate. On the "Programs and Features" screen it reports "Intel Management Engine Components", the size is "20.4MB", and the version is "6.0.0.1179". Is this not it?
Edit - I'll bet the answer is no because I checked the version on Intel's page and they did not match. So I d/l'd it and it installed without error and asked for a reboot. Although I do not see it on the "Programs and Features" or any place else I looked (another thing I hate about w7).
post #3275 of 3675
Which H55M are you referring to? There are many variants (vanilla, USB3, GE, LE, Pro).
post #3276 of 3675
Oh, sorry about that - it's a H55M/USB3. How do I confirm the MEI driver is installed?
post #3277 of 3675
H55M/USB3 is one of the ASRock 2nd generation H55 mbs that support Intel MEI and HD audio bitstreaming with every commercial BD player (as well as ffdshow Audio Decoder).
You should see "Intel management Engine Components" in Program > Uninstall. Or just play a BD movie with PowerDVD or TMT and see if HD audio bitstreaming works (if it works, MEI is installed).
post #3278 of 3675
Originally Posted by HTPCat View Post
I am not sure, but I don't think you can bitstream TMT3 from file so how about trying to play from folder (this is how I play all of my 300 + Blu-rays). Open TMT3 .180 and at the bottom click on folder to select source and then click on Open disc folder then point to the folder with the volume label of the movie like Avatar or The Dark Knight the OK button should light up and then click it and it should start playing - hopefully bitstreaming DTSHD-MA.
Thank you so much, HTPCat, under your inspiration and help, I think I found my solution for HD Audio Bitsteaming.
For all the iso files, I use TMT 3 to bitstream, by using Deamon Tools to mount the iso file as a bluray disk.
For all the bluray files (with "BDMV" and "Certificate" folders), drag "BDMV" folder to TMT3. It did not work until I found there are some bluray disk folder missing, and using a little tool called "bdrom.rar" to complete all the missing folders. You will need this tool to complete all the folders before you create an iso file if you want to.
For all the rest, such as Remux bluray files, I finally found PotPlayer can bitsream today.
my setup is Gigabyte H57USB3, i5 650, MEI Installed. TMT3 version 185, Potplayer newest version.
It took me 2 weeks to find out above, under warmest help from many friends here. Thank HTPCat again.
Hope these can help others as well.
post #3279 of 3675
HARDWARE-INFOS
INPAI.com.cn
  Clock Core Threading L3 cache TB 2.0 TDP
Core i7-2600 3.4GHz 4 8 8MB Yes 95W
Core i5-2500 3.3GHz 4 4 6MB Yes 95W
Core i5-2400 3.1GHz 4 4 6MB Yes 95W
Core i3-2120 3.3GHz 2 4 3MB No 65W
Core i3-2100 3.1GHz 2 4 3MB No 65W
So
- Core i3-530/540 -> Core i3-2100/2120
- Core i5-750 -> Core i5-2400/2500
- Core i7-860/870 -> Core i7-2600
GPU is integrated in every Sandy Bridge processor.
Edit
(August 12): Additional model numbes (K [multiplier unlocked], S, T [lower power] versions).
Computer Base: Neue Roadmap: „Sandy Bridge“ entschlüsselt
post #3280 of 3675
HARDWARE-INFOS
INPAI.com.cn
So
What's TB 2.0?
The the segmentation b/w i3 and i5 is interesting - wonder what the perf penalty for the 30W...
post #3281 of 3675
Turbo 2.0. Core i3's are dual-cores, i5's are quads w/o hyperthreading. My guess is that it's about the same performance penalty as Clarkdales and Lynnfield Core i5's.
post #3282 of 3675
You mean TurboBoost (temp single core overclocking)? If that's the case, SandyBridge i3 is looking good.
post #3283 of 3675
Yeah, turbo boost. I have no idea what the 2.0 means, I just went by the translated pages. Mewants an i7.
post #3284 of 3675
- Turbo Boost 1.0: OC CPU within TDP (CPU)
- Turbo Boost 2.0: OC CPU & GPU within TDP (CPU and GPU combined)
post #3285 of 3675
Is anyone else still having this problem?
post #3286 of 3675
I read the general monitor support is 3, and mobile versions can even work with the discrete graphics to enable more.
Where is the 3D Blu-ray supporting driver? Intel is late again! I hope the 15.18 version do proper 23.978 support, along with the 3D Blu-ray.
post #3287 of 3675
No one has a publicly available 3D driver, so late is a bit harsh.
post #3288 of 3675
Haven't you seen the presentation by Intel saying "Blu-ray 3D by summer"? Well its well into summer now and heading into fall.
post #3289 of 3675
Did Marketing say which year? They're tricky that way...
post #3290 of 3675
Actually, they did
http://www.engadget.com/2010/06/01/i...e-widi-laptop/
post #3291 of 3675
Hi Tony7711, can you please tell me where i can get what you call "bdrom.rar"?
post #3292 of 3675
Actually, they did
I suspect it's very close-- there are employee demos in the upcoming weeks. Still, I won't pretend to know the details of schedule.
post #3293 of 3675
I7 cpu's are great!
post #3294 of 3675
My main HTPC is a Intel H55 mobo with i3-530 cpu and win 7x64. I am using the Intel igpu video/audio HDMI to my Denon AVR 4310 and everything works great (DVD, BD & HDTV) except I just noticed an issue with music playback. If I am playing back an mp3 file in WMC or WMP outside of WMC once I stop/pause the audio when I hit play from a paused audio track or try to play a new song after stopping a file I don't get any sound unless I click the audio source button on my remote (stereo or 5/7 channel stereo, etc.). This happens if I am bit streaming or with multi-channel decoding by windows.
Is this normal with this setup ? If not, is anyone else having this issue? Do I need to change a setting or something? It is not a huge deal, but it is sort of annoying .
post #3295 of 3675
How do you have your Windows playback device configured? Is it set to 2 channel/stereo?
post #3296 of 3675
I have tried it with 2 channel/stereo and 7.1. Both give same results as far as getting no audio after pausing or stopping a mp3 file and then attempting to restart or play another mp3 file.
post #3297 of 3675
Have you installed any codec packs?
post #3298 of 3675
No codec packs have ever been installed.
Software for playing BD's is TMT3 .185
Software for playing DVD's is MPC-HC
Frontend is WMC (win 7 x64)
MyMovies 3.16 plugin
Latest intel drivers
post #3299 of 3675
Maybe there is some weird issue going on between the default shared mode setting under the Advanced tab in the audio settings and your receiver. If you have a beer for me I can take a look at it
I am running a HTPC with an i3 530 and got bitstreaming and DXVA working great after a little research. I HATE codec packs but trust and only use one: Shark 007.
I use XBMC for everything except live tv which I use WMC 7 for. What's really cool is since my Win install is 64 bit, I have different settings for 32 bit and 64 bit players. A lot of advanced settings can break live tv in WMC but since almost all players are 32 bit, they are separate from WMC which is 64 bit.
Anyways, check out the shared mode. If that doesn't work let me know if you need a hand.
post #3300 of 3675
I don't know if this is an issue with all HTPCs or just the new i3/i5/i7 chips... this is my first HTPC and it's a i3.
I want to listen to music with my TV off. I'm using iTunes. I start a song, but when I turn off my TV, the music stops. Sometimes it turns back on, sometimes it doesn't. I can't seem to find a pattern or rational for why sometimes it works and sometimes it doesn't.
Any ideas?
