Originally Posted by alanbrenton
Here you go:
EB Series (what I'm considering):
http://www.sonystyle.com/webapp/wcs/...52921644699999
I was thinking that because these units can be upgraded with the ATI 5000 series GPU and because the basic underpinning of the Intel iCore processor + Intel HD combination supports bitstreaming, I can use the proper GPU accordingly for various needs to bypass any issues like the 23.976Hz for Intel and maybe some others for the ATI GPU.
I am hoping a subject matter expert can enlighten us whether these notebook combinations will do great as HTPC alternatives.
Here you go:
I looked into the customization aspects in the link above and also talked with our resident notebook reviews senior editor, Jarred Walton. This is what I have from him:
i3/i5 can handle HDMI no problem. It's only Atom that can't do HDMI. So the HDMI/VGA/LVDS all come off the IGP on NVIDIA Optimus, and with ATI they have hardware muxes to switch the output from the IGP to the dGPU. But, ATI switchable graphics means you're locked into Sony for driver updates, which sucks.
However, the EB series you are considering doesn't advertise 'switchable graphics'. So, it looks like the dGPU will completely disable Intel HD graphics.
You will be better off with something using Optimus (nV) which is much more popular compared to ATI switchable graphics. Also, the latter is dependent on vendor driver updates, but Optimus works well with driver updates direct from nV.
Of course, there are people who prefer ATI, and for them, I would suggest not trying to use Intel HD Graphics on the same m/c, but that is just my opinion.
