Apparently PDVD has issues with this IGP.
I would have to say so does TMT3, at least in my experience so far. It won't even play DVDs. Get nothing but black vertical lines across the screen. WMP doesn't do this. Tried the trial of PDVD9 and it seems to work fine for DVD and Blu ray. Haven't had much time to really test it yet.
I'm not used to the display settings for this IGP, I would assume refresh rate equals FPS? I really didn't have much experience with this setting for the nvidia 9300 igp. Should this be set to 24hz for Blu ray if the TV will accept it?
The default setting when using extended desktop to a Panasonic LCD is 30hz
which seems to work O.K. with PDVD for DVD and Blu ray.
