I need to put in about a 30' run between 2 receivers (theatre & family room). Standard cable is picking up too much garbage and I assume is also the reason for lack of low end on receiving system.
Can anyone recommend product/mfr/vendor for a decent quality cable that will work better. Looked at bettercables, but the $150 per cable (eg $600 for 2 channels each way) is a bit hard to swallow. Other searches haven't turned up much.
Aslan...
Aslan...
