AVS › AVS Forum › Audio › DIY Speakers and Subs › Help picking a plate amp
post #1 of 28
I'm trying to decide which plate amp to buy to modify a POS I picked up for cheap. Its an Acoustic Audio with a rather large fan base. I paid 98$ for it so it isn't a bank breaker that it turns out to be a steaming pile.
Its a 10" slot ported down firing sub with 200 watt amp and a driver that can't keep up - I've replaced it with one a neighbor sold me for 10$ - a Rockford Fosgate 10" P110s4 model.
Specs are:
Sensitivity: 85.5 dB RMS
Power Range : 50-150 Watts
Peak Power Handling: 300 Watts
Impedance: 4 Ohm
Low Frequency response: 20 Hz
High Frequency Response: 200 Hz
Diameter: 10 Inch
After putting the Rockford driver in it sounded much better. On the LOTR intro where Isuldor whacks the ring off the bad guy it actually sounded pretty good for as small as it is. Trouble is the amp gets very hot - it will blow - just a matter of time - so I need a cheap solution so I can get on with other things. The original AA driver is a dual voice coil - the Rockford is a single so I 'bridged' the dual leads from the amp to the new driver and tried it out. With single leads very little sound is produced.
So....recommendations on a plate amp for this that will work with this driver? I've looked at a few such as this Hafler being offered up on ebay - a Foster which I've never heard of before but the price certainly is compelling. It puts out 110 watts - will that be that enough for the Rockford? I'd really like to keep this under $100 - the Rockford driver will end up beating the hell out of this enclosure as it is. Another one I've been reading up on is the Dayton SA240. At some point I see myself visiting my buddy Mick to saw up some MDF and building a decent sealed enclosure for this.
FWIW if anyone reads that forum I linked to and is thinking of trying one - don't. I've seen fan based forum threads but have never seen one quite like that. The main 'cheerleader' of the AA subs is also a moderator and tends to mildly flame any detractors that has a bad experience - his minions do not exhibit the same restraint, following along thinking they are in audio nirvana by having one of these subs. His graphs and charts showing a 12" AA sub besting a DIY with a Dayton 15" Titanic driver is laughable. In that 'test' the Dayton barely got over 100db.
post #2 of 28
Just above $100, but the PE 240w w/ Boost would probably would as well as can be expected with that drive and enclosure. I'm not sure where the high-pass is set, but it should give some protection against bottoming.
Another option a bit more in line with the overall budget nature of the build would be the surplus Foster WF-100K for $35 from the NHT Surplus Sale if there are any left. It's 110w at 4ohm, has a 29hz high-pass, and an adjustable 10db shelve can be modified using data available from the sale website.
post #3 of 28
The Rockford recommendation for that driver is for a 1 cubic foot sealed enclosure - nearly the same as what I have so sealing the slot should work and help the driver from bottoming out as well.
Do you think the Foster amp will drive this with any reasonable SPL levels?
post #4 of 28
Keep in mind that the Rockford Fosgate reccomendation for that driver is for car-audio (enclosed space, cabin gain) as well as music (far less subsonics and near subsonics). I'd play some modeling software and compare enclosures for the driver. You know the volume (roughly) and port size/length, so you're really just comparing the FR curve and output of sealed vs. vented. Since you're looking to replace the amp anyway, you don't have any unknown boost characteristics to deal with.
I'd say the PE amp would noticeably increase output over the Foster, which may or may not noticeably increase output over the stock amp... but with the Foster amp you have a clean slate (no unknown boost) and you're not sinking a lot of money into an unknown. A $110 amp probably isn't going to make this project $75 better than the cheaper Foster amp. Buy the cheap amp to play with what you have, and buy or build a better sub when you're ready to upgrade.
post #5 of 28
Very happy with several NOS Hafler/Rockford 100 W plates I have used. E-Bay for around a buck, something like that. Don't know if there are any left. I might grab a couple more myself.
post #6 of 28
The original driver made some horrible noises. Playing the intro to LOTR where Isuldor hacks the ring off the bad guy - when the sound visually and audibly radiates out - the only way I can describe how it sounded is like a Jake Brake on a big rig coming down a long steep incline. Not even close to the sound from my Infinity PS212 - a decent if not great sub. With the Rockford driver it sounded almost exactly like the Infinity - just not as loud.
I just ordered 2 of the Foster amps from this guy. If they don't work out where can I get one of those? I have a link in my first post to a 220 watt Hafler on ebay - just not willing to spend $130 + for it.
The Foster amps can be bridged making them 220 watts into 8 ohms. Can they together drive a 4 ohm speaker such as the Rockford I have?
post #7 of 28
I was late to this thread, I have 4 of Jack's amps in my garage unused.
post #8 of 28
I don't think you're going to have much luck bridging them with a 8ohm load. I really wouldn't sink much more than the cost of one of the Foster amps into this unless you plan on reusing it building an HT oriented design later on. Any more than the $35 a surplus Foster 110w costs seems like throwing good money after bad.
post #9 of 28
Any reason why you haven't used them yet? Are they any good?
This works out for me - I have a friend with a old sub that quit working and he's been bugging me to help him fix it. Its a single coil driver and these Foster amps are single lead output. Maybe I'll sell him one of them for the price of two. Won't cost me anything!
post #10 of 28
Now that's thinking with your dipstick, Jimmy!
post #11 of 28
Which is why I ordered two!
And my buddies name is Jim(my)!
I'll charge him what the amp cost - I'd never do that to a friend. I just hope it'll fit on his little sub - its a plastic one - an Insignia I think. Maybe we could duct-tape it to the top His wife would love that. She likes the little bitty speakers - but can't figure out why my HT sounds better than theirs!
Funny thing - when they went shopping for a new TV she kept wanting bigger!
Typical woman.
post #12 of 28
Are they any good?
Just wanted to drop in and say I picked up 4 of these to put onto some unpowered eD 12" subs I had left from the last upgrade and sell them on Craigslist (I'm keeping the EP2500 ). I'm quite happy with the performance and believe they put out a true 110W (that's not just their "rated power" it's actual).
Funny story, I had a guy come over to look at the subs. He'd just bought an Infinity sub rated at 500W from Best Buy but was unhappy with it. He demo'd the large ported eD sub using one of these plate amps and was blown away. He didn't want to spend the $175 on the sub I was selling since he already had the Infinity and didn't want to pay for return shipping (we're in the middle of nowhere!) but asked if I'd sell just the plate amp. $75 later and he was on his way with one. I wouldn't have charged him so much but I figured if I sold it at $75 he'd be back to trade up to the ported sub for another $100 for sure. I emailed him the other day and he was ecstatic with the performance of his Infinity with the new amp. He said the "500W" infinity amp wasn't half the size or weight of the Foster amp, go figure
post #13 of 28
Are you saying they are no good? Im pretty sure Jack, NHT would disagree with your opinion. You can ask jack about the Bridging, from what I have read it can be done.
post #14 of 28
Definitely not saying they're no-good... just saying that bridging them with a 4ohm load might be pushing the limits of their abilities... that would be the equivalent one amp driving a 2ohm load. If Jack says it can be done, I definitely believe it, but his site says they can be bridged for an 8ohm load.
post #15 of 28
For the $$$ they can not be beat period!!
I haven't used them for the same reason I havent used the other $2000 worth of drivers sitting in my garage
Too many projects, too little time....I couldnt pass up on them and the 10" 081s that Jack was selling many months ago. A bass bin for $70 is sick and Im happy I bought many things from him including incredible VR-3 kits! Most of the stuff now is sold out but I have great value for future projects.
Any neighbor or friend that wants speakers is going to love me
post #16 of 28
Oh, sorry I misread your post....Yeah 2 ohm wont work.
but since he has a 4 ohm driver two bridged amps giving him 200W into 4 ohms?
post #17 of 28
Thats encouraging, thanks. It should power the Rockford Fosgate driver I have OK. 110 watts is in the middle of its handling ratings. Those amps are being sold for $35 each. I don't see how you can go wrong - and for under $100 for 2 its a cheap education if they prove to be dogs - which sounds unlikely with what you are saying.
I'm stuck at home today waiting for a new sub to show up - I bought an eD A5-350. It should be capable of showing my Infinity PS212 how to sound off. Not sure if the Infinity will go into the bedroom or if I should let this little sub go in there.
We shall see what we shall see - or hear in this case.
post #18 of 28
Not sure where I read it but Jack said he tried bridged into 4ohms and the amps went into protection so that's a no-go. I'll see if I can find it.
Edit: Found it, it's in the FAQ located on his page:
"When two WF-100k amplifiers are bridged together, the load must 8ohms or greater. I tested this setup with a 4ohm load and the amplifiers instantly went into protection. It may work with a 6ohm load. I don’t know. Into the 8ohm load, the amplifier pair delivered 220W at 1% THD at 50Hz."
post #19 of 28
"When two WF-100k amplifiers are bridged together, the load must 8ohms or greater. I tested this setup with a 4ohm load and the amplifiers instantly went into protection. It may work with a 6ohm load. I don't know. Into the 8ohm load, the amplifier pair delivered 220W at 1% THD at 50Hz."
If these amps work as well as suggested I may have to pick up a couple more before they are gone. Using 2 of them on a dual voice coil driver should produce some amazing results. Maybe a 15" DVC.
Do you have a link to that thread you are referring to?
post #20 of 28
Which thread? If you mean the quote from Jack I got it from the Foster WF-100k amplifier FAQ, it's the first link under the Foster amps on his page that you linked above:
http://home.comcast.net/~jhidley/
There is a thread here that Jack's been posting in regarding the items he has for sale but there's not much discussion of these amps there:
http://www.avsforum.com/avs-vb/showthread.php?t=1125860
post #21 of 28
Damn, I may have to go shopping for a table saw and make a few subs.
Thanks for the links. I ordered 2 of the Foster plate amps today - and thinking about another 2. I'll wait and see how one works for the little AA sub. The Rockford driver sounds great with music - bass guitars actually sound like bass guitars. Cellos sound like cellos! Imagine!
So even though the amp in this AA sub works and the driver is the real POS it gets very hot. It would probably burn the sub up if left on - the auto off seems not to work either - what a shock!
Anyone have a recommendation on whether radial or table saws are easier for making subs? My bet would be on a table saw - but I have a very small garage - and a motorcycle takes up a large part of that space.
Also - could 2 of the Foster amps be used to power a dual voice coil driver of 12-15" without problems? I have no idea how the wiring is connected in dual coil drivers - or if they are even connected at all.
post #22 of 28
A table saw would be best but a circular saw will do for a one-time sub build... I was thinking you were on a tight budget but now you're buying a table saw for a new sub build??? And just ordered an eD A5-350??? If you do make a run at a DIY sub what would the budget be and what kind of performance are you looking for? HT/music? Size restrictions?
You could wire it that way but it would be messy. Any gain settings or crossover settings would have to be performed on each amp separately. Usually with a DVC sub you'd wire the coils together in series or parallel depending on the load you want to present to the amp - wiring in series will double the impedance of one coil, parallel will halve it. So a sub with two 4ohm voice coils could be wired in parallel for a 2ohm load or series for an 8ohm load. Most of the amps commonly used won't drive a 2ohm load though.
post #23 of 28
My thought for buying the AA sub was to use it in the bedroom where I have a 5.0 setup and wanted to add a small sub. I was happy with the Infinity pS212 in the living room.
After getting that AA sub and realizing I got screwed - AA hasn't contacted me after 3 emails in 2 weeks so I got to thinking about using the PS212 in the bedroom and getting a bigger sub and ended up getting a good deal on the A5. So I bought the A5 350. Just got through watching my first movie with it - Blade Runner - haven't seen it in some time.
The A5 is an awesome sub - the Infinity sounds almost like a toy by comparison - although it does very well with music.
As brutish as the A5 is it does an excellent job on music as well. Bach's Tocatta (pipe organ) is fantastic. Cellos sound like cellos.
The table saw idea was more like thinking out loud than something I'm likely to do. I have enough hobbies and don't need more. It would be fun though - and I have some skill in wood working. I used to borrow my Dad's work shop on occasion and build stuff. That was years ago.
I've ordered Foster plate amp and it will fit into the AA sub. With a good amp I won't have to worry about it burning up the house.
Now I just have to find a place for it.
Hmm...wonder if it would work in my SUV as a sub with the right amp?
Just kidding. Well, maybe not!
post #24 of 28
Wow!!! What a thread that guy has going over there on the forum you linked too!!! My goodness!!! I wasn't about to read all 100+ pages but I read more than enough on the first couple of pages to know what was going on...I am no schill but have been calledone for being a bit too enthusiastic about certain things that I write about...
OK...Sort of hard trying to figure where I want to start based on your questions and the other excellent advice you have already received...I guess the first thing I should state is that I am only stating my opinion and you can take what you want out of it...However please be aware that my opinion(s) are ALL based on actual experiences of mine and I am not fabricating anything...
Well lets start with the sub you bought that is a POS...While I know nothing more about the sub other than what I have read I feel confident in saying that for the price I am sure it is not really a POS but rather won't do what YOU want it to do...Nothing wrong with that as it was never meant to be that kind of sub...
Most subs will benefit in a huge way by simply upgrading the driver...Now the driver you used is absolutely better than the OE driver...However it is still a car sub and while it works it is not fair to expect it to perfrm well in the environment you are using it...For $10 I would probably do the same...Now the reason the OE amp is getting so hot is because of 2 reasons...The first is because you are using an 8ohm amp to drive a 4ohm load...The added strain makes the amp work harder which causes the heat...The second is because you have the amp that is already working hard turned up I am sure to get the output you are looking for...Again there is nothing wrong with that but is the reason for the heat...The amp will certainly cease working sooner than later if you keep using it like this but I sincerely doubt any fire will occur...
Now as for what is the best amp to use...That Foster IF it is as nice as has been posted is hands down the best way to go...But be warned that you intend to use an 8ohm amp on a 4 ohm load so you will have heat issues again IF the amp does not go into self protect mode first...And according to one of the replies here it states that the amp MAY be able to run 6 ohm but certainly not 4ohm and 8ohm is ideal...But when I look at the actual specs it does state a 4ohm load will work...Regardless a 4ohm load will make the amp hotter than an 8ohm load...
Now honestly if it were me I wouldn't worry about buying a table saw and building a cabinet...How is the AA cabinet??? Is it decent??? is it the standard 5/8 to 3/4 thickness??? Is the baffle thicker than the other 5 sides??? if the answers are yes to all of the above then this is what I would do if you really want the best for as little cash as possible...The Dayton 240watt plate amp for $109 + free shipping...Pick up this driver:
http://www.parts-express.com/pe/show...number=299-106
or For even less use the Foster amp you just ordered and get rid of the Rockford driver and get this one instead:
http://www.parts-express.com/pe/show...number=295-485
You will be amazed with what these drivers can do...VERY impressive...I have the 12" DVC and it seriously rocks...Go to a hobby store and get some poly fill as it is cheaper that way...You do the 2nd way and you'll have a sub that rivals $300 subs from Best Buy and the like easily...
Also don't be concerned about having dual leads from a plate amp when using a DVC driver...You can connect only 1 coil and be fine...Won't hurt a thing...Or you can connect the coils in series or parallel...Personally i would use them in series to make it a 4 ohm load for the Foster to drive...Now don't forget as nice as the Fosters are supposed to be they aren't THAT nice...The power supply and capacitors I'm sure are no larger than absolutely necessary for cost reasons so don't expect a whole lot from them...The BEST is to use the 240watt Dayton amp and the second driver I linked to connected in 4ohm for the best 10" sub for cheap...
It's late and I may have rushed through this but I think I have made my point...Take what you will from it as little or as much along with the other suggestions and you'll be fine...All I can say is I take cheap subs with decent amps and replace the drivers all the time and the sound is incredible...As a matter of fact I am using a sub I bought off the internet with a 150watt plate amp but it has oversized capacitors and a torroidal (sp?) power supply in a curved cabinet I paid $129 shipped for and removed the POS driver that constantly bottomed out and replaced it with this:
http://www.parts-express.com/pe/show...number=295-464
Added some poly fill that I had sitting around and re-veneered the cabinet and I will put it up against any $800+ sub for sound quality...And I sold the old driver for $35 on ebay so my cost ended being $237...Pretty respectable I think...
post #25 of 28
Sorry if it wasn't clear but the statement was regarding bridging two of the plate amps together to push a 4 ohm load (so essentially the load to each amp would be 2 ohms). The amps will push 4 ohms just fine
That's true for the most part. It likely won't hurt anything but it does lower power handling and alters the T/S parameters. Using only one coil will double the QES. Here's a great page with more detailed information on options for hooking up DVC drivers:
http://www.geocities.com/f4ier/dvc.htm
I honestly think that the Foster amps will put out near the same as the Dayton 240w amp. I don't have anything to base that on other than the other Dayton amps tested didn't produce anywhere near rated wattage whereas the Foster amps were able to. Also the two amps are nearly the same size and shipping weight.
post #26 of 28
Splicer & lennon
Thanks for the information.
I don't think I'll be running out and buying a table saw any time soon. Last thing I need is to be knee deep in subs.
The improvement in this sub with just the driver change was immediate and very apparent. For a car sub it certainly sounds better than the original - a stiff paper cone with dual coils. You're probably right about the original amp - it'll run hot until something just gives inside - it gets way too hot to put my hand on for more than a few seconds. I could use it for a branding iron.
The way I look at it is if I did nothing with it I'd be out 98$ and I could just throw it away and be done with it. Putting in a 10$ driver helped - now I'm into it for 108$ so whats another 35$ or so? And I like playing around with things to fix and improve on them when I can. The Foster amp is right in the Rockford drivers amp levels so it should work out great.
I got this sub to put in my bedroom - I don't need much sub in a 14x13 sealed room. For $100 it was worth a shot - I didn't expect much from it and it didn't give me much - in fact less than I'd hoped for. The trouble is it can't even perform at a close to acceptable levels. I took the manufacturers specs with a grain of salt - they don't even have these subs listed on their website any more and none on ebay - where I bought it. Volume was the first problem I noticed - it had very little even with both RCA jacks active. At any high volume transient sound it bottomed out - sounding more like a high speed rod knocking inside an engine than anything remotely close to a sub. It did ok on low music - I couldn't distinguish a bass guitar from a bass cello. There was no definition to the sound.
So - I have a Foster amp coming that should wake up the Rockford driver I have in it.
post #27 of 28
I'll bet! You've certainly moved to the next level from the Brick and Mortar subs
Thanks for the explanation of what you're trying to achieve too. It makes perfect sense when you lay it out like that, it just threw me off. Be sure to let us know how it works out.
post #28 of 28
I'll do that.
My experience with subs is limitied - I've had them in built in speakers - the Infinity Interlude IL50s - and after selling those I bought a JBL E150P. That was worse than the IL50s - bass was indistinct and mostly just rumbling sound came from it. When I got the PS212 WOW what a change! I now had a sub that I could identify a bass guitar from a kick drum. So now I have a REAL sub - the A5 350. This thing is a monster! I knew it was big when I ordered it but like usual - reality sinks in when you have the product in the house and you are left wondering where the hell you are going to put this thing.
I watched Blade Runner last night and the difference between the PS212 and the A5 isn't worth going into other than I've never felt the floor move before!
