Basically installed Windows 7 got device drivers installed including the latest 9.8 ATI Driver set the resolution on the TV to 1920x1080P 60Hz and then went to locate over-scan correction as it does the stupid (very stupid in this day and age) - 10% area. The problem is there is no option to adjust this in The Catalyst Control Panel (DUH!). Without this the use of Windows 7 and ATI for an HTPC if using Audio over HDMI is 0, Nada, Waste of time.
I'm a little surprised I could find no other post about the glaring flaw with using Windows 7 and ATI on an HTPC, but since I found none I'm creating this thread to warn people away from this combination at least until ATI can get around to fixing this issue (with their track record that could be years), stick with Vista at least with SP2 installed it works!
On upset customer, ATI!
ERIC
ERIC
