Originally Posted by
jtl46
Thanks, good to know it is by source. When I looked at the 54G20 and the 58C550 at Sears I thought the Panny looked "brighter" but they were at opposite ends of the room so it was not easy to compare them. Could you share your settings with me, maybe I can adjust them at the store and see how it looks.
Unfortunately, home setting will be useless in the store. The picture will look too dark. If you are testing brightness in the store, the only thing you can do is set it to Dyanamic mode and hit reset (just in case someone has been messing around with it). This will give you the brightest picture I believe you can get. Cell light, contrast, etc will be maxed. This is basically "torch mode".
Keep in this is FAR brighter than you will probably need in your home.
Now if you have alot of ambient light in your room, I will say that the c550 anti-glare is OK, not great. But it's not an issue in my environment.
